Wheel Chair Ramp - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-18-2010, 05:55 PM   #1
liscenced electrician
Rewards Points: 538
wheel chair ramp
Im going to build a wheel chair ramp at a friends house and im not sure how to frame it out. What is confusing me is that that the door is only 12 or so off the concrete slab, so if i use 2x12 or 2x10 stringers plus some sort of decking on top, it doesn't leave any room for framing underneeth. So how should i go about framing it out? Ive never built one of these. And should i use treated 2x6's or plywood, or what for a deck? There is maybe 30' that this thing could be long, but it probably doesn't need to be anywhere near that because its only 12" rise
im attaching a drawing so you guys can understand what needs to happen.
jimmy21 is offline   Reply With Quote
Old 04-18-2010, 06:07 PM   #2
Max rise is 1" per foot for public access
So for 12" that equals 12'
http://www.newdisability.com/wheelchairramp.htm
1:16 or 1:20 is preferred...so 30' is a distance
http://www.mobility-advisor.com/whee...amp-specs.html
PT would be the best bet
or some other rot resistant wood
Old 04-18-2010, 06:24 PM   #3
Rewards Points: 538
thats some good info
any idea of what to do underneath for the framing though?
Old 04-18-2010, 06:32 PM   #4
DIY staff
Rewards Points: 7,174
The codes Scuba Dave referred to a ADA codes for public buildings--You are allowed to create a steeper rise for a residence.
The big question to ask your self is how capable is the person in the chair.
Think about the landing size also--will there be someone pushing? does the door swing out?
4 foot in front of the door works well.---Hope that helped.--Mike---
If you could post a picture of the existing porch area--I guarantee you will get several simple framing suggestions.
WillieT might even step in with his magic pencil!--M--
Old 04-18-2010, 06:45 PM   #5
DIY staff
You may not need any fancy framing--- you mentioned ripping long tri-angles out of treated 2x12s
That would work--and be efficient use of the boards.---See if you can get a shot or two of the work site.--Mike--
Willie T (04-18-2010)
Old 04-18-2010, 06:51 PM   #6
I would use PT decking, that will allow rain to run off
Rise will depend upon if someone will always be pushing the person
Being pushed 1:12 might work
Or if they will be wheeling themself up the ramp how strong they are
I see ramps being given away for free on Craigslist every now & then
Also, if you know of any ramps in the area check them out
Have the person wheel up the ramp or push them & see how it works
Old 04-18-2010, 09:52 PM   #7
Rewards Points: 538
it will be used for being pushed up. The friends parents are old. Not the friend.
If i rip 2x12s to the angle i need. How do i attach them at the ground? Maybe i'll draw a pic of what im thinking for the landing side attaching to the ramp
Old 04-18-2010, 09:58 PM   #8
Registered User
Rewards Points: 5,498
"I would use PT decking, that will allow rain to run off" ----- only if you don't use any fasteners and waterproof it first. Be sure to use the correct fasteners. "Since it contains high levels of copper, ACQ-treated timber is five times more corrosive to common steel, according to test results. It is necessary to use double-galvanized or stainless steel fasteners in ACQ timber. Use of fasteners meeting or exceeding requirements for ASTM A 153 Class D meet the added requirements for fastener durability." From: http://en.wikipedia.org/wiki/Wood_preservation
"Does pressure-treated lumber need waterproofing?
Yes. Pressure-treated wood is pretreated with chemicals to prevent insect damage and rot. It is not waterproofed. The chemical treatment actually causes the lumber to dry out quicker and absorb more water than untreated lumber. When wood absorbs water, it swells. As the wood dries, it shrinks. These cycles cause wood to crack, warp and split - this is typically what is meant by "water damage." Thompson'sŪ WaterSealŪ brand offers the most powerful protection against water damage, guaranteed." From: http://www.thompsonswaterseal.com/advice/faq.cfm
Be safe, Gary
Old 04-18-2010, 10:48 PM   #9
A box frame attached to the house and 4X4 posts on the outside for the platform and handrail attachment. The same 4X4 posts on the ramp for support and to attach the hand rail. The platform close to the bottom of the door and the ramp at least 12' long. Use one inch PT decking boards leaving a gap for drainage.
hayewe farm is offline   Reply With Quote
Installing Chair Rail up staircase? tomrash Carpentry 7 07-14-2011 12:42 PM
Painting/staining crown moulding and chair rail Gypsy601 Interior Decorating 8 07-05-2011 03:51 PM
comfortmaker rpj2 blower wheel problems nuclearjesus HVAC 3 11-22-2009 08:14 PM
Wheel Chair Ramp to Curved Step PaliBob Project Showcase 0 10-27-2009 04:35 AM
Don't want to build a wheel chair ramp. Any ideas? jizzle Building & Construction 7 12-22-2008 10:47 AM
