What's Wrong With This Concrete Finish? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-02-2011, 08:09 PM   #1
What's wrong with this concrete finish?
Hi all, I new and hoping I'm putting this post in the correct place.
I had all new concrete poured for a new driveway and walkways in my front yard about 3 months ago. I'm wanting to seal it before winter but am concerned by the inconsistant look on the surface and don't want to "lock-it-in" until I understand and am able to improve it, if I can. Basically, it's colored concrete with off-colored color powder applied while it was wet. Some of it is stamped with troweled bands. The contractor taped plastic over the bands so the powder would only get into the stamped areas. I think they removed the plast too soon as you can see broom marks on the bands in places.
My question is this - I've tried removing the broom marks/powder from those areas with an electric power washer which did almost nothing. Is there any way of getting this stuff off of those areas where they shouldn't be, maybe a more powerful power washer or etching acid? Any ideas?
I'll try including a couple of pictures, I hope they upload ok.
Joepublic is offline   Reply With Quote
Old 09-02-2011, 08:14 PM   #2
I thought I would include an additional photo,
Old 09-02-2011, 09:01 PM   #3
DIY staff
Rewards Points: 7,174
Did you contact the installer?
There are several concrete people here---One should be able to help.
Old 09-02-2011, 10:50 PM   #4
I tried to get the contractor to come out and evaluate the finish but to no avail. I planned on sealing it myself once I figure out what to do with the concrete surface.
BTW I'm out in the San Jose area of Northern California.
Old 09-03-2011, 04:47 AM   #5
jpc
jc
Rewards Points: 162
Send a message via Yahoo to jpc
you could water down some hydrocloric, or muriatic acid, and acid etch that little bit off, dont let it sit on the concrete too long, and clean it off with a pressure washer, not a huge powerful one, u want the acid to do the work, the pressure washer is only used to clean it all of so it doesnt continue to eat, good luck
jpc is offline   Reply With Quote
Old 09-03-2011, 10:31 AM   #6
Concrete & Masonry
Rewards Points: 470
Two questions:
Has it not been sealed yet by the contractor?
How does it look when it's wet.
I don't think you're going to be able to get rid of any broom marks in it w/o taking off most/all the surface color in that area.
jomama45 is offline   Reply With Quote
Old 09-03-2011, 01:01 PM   #7
Thanks for the responses. It looks just as bad when wet. I remember the look was supposed to be mottled around the stamped areas but they put so much powder on, they ended up changing the color altogether. It's now mono colored to the color of the powder, but when they swept off the excess powder, they did it after they had removed the protective plastic from the bands and before the concrete had a chance to set more, thus the broom marks from the powder on some of my bands.
I think I'll try a muratic acid solution on a small corner of a walkway on the side of my house that isn't seen much.
Thanks again for the suggestions
The Following User Says Thank You to Joepublic For This Useful Post:
oh'mike (09-03-2011)
Old 09-03-2011, 07:20 PM   #8
Actually I found a bottle of concrete acid etch in my garage/shop cupboard (hydrochloric and Phosphoric acid based). I applied it to a portion of concrete band kinda mottled with broomed-on powdered color. I followed then instructions applying it full strength and scrubbing it with a stiff brush. I then waited a few minutes and washed it off with a power washer.
After it dried it looked worse. All the acid did was to desolve the powder a little and etch it into the rest of the concrete making it mono colored to the color of the powder.
I think I'm stuck with this concrete look, ugh!
Old 09-04-2011, 08:31 AM   #9
Just clean it and apply a Epoxy based product (NOT ONE FROM THE CHAIN STORE ) I have an industrial epoxy on a slab of mine that forklift
works on daily and is holding up, I know the product exist just dont know the name
Coconut
coconut sunrise is offline   Reply With Quote
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 04:49 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
