Whats Used For Outside Corners On Fiber Cement Siding? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-31-2013, 06:06 PM   #1
Whats used for outside corners on fiber cement siding?
Whats used for outside corners/inside corners on fiber cement siding?
DukeLewis87 is offline   Reply With Quote
Old 05-31-2013, 06:11 PM   #2
747
registered
747's Avatar
Rewards Points: 534
You could do a compound miter cut to make it look sweet. However this is labor intensive and only a skilled guy could pull it off. Where they meet each would be a compound miter cut.
747 is offline   Reply With Quote
Old 05-31-2013, 06:24 PM   #3
Rewards Points: 12,832
I gave up long ago on trying to use the James Harddee 5/4 trim. 1/2 the time it brakes before I can get it to the job. Hard to fasthen. Leaves a seam.
I use Vinyl premade outside corners with the dato already made into them.
Not cheap but no seam, never broke one.
Any real siding supply will have them.
Old 05-31-2013, 06:32 PM   #4
http://www.menards.com/main/building...105-c-5824.htm
10' Outside Pvc Corner
Is that what is used for outside + inside???
Old 05-31-2013, 06:43 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
no one mitres harti plank it cant take abuse. its too brittle. .you need a corner post
for the corner you can do it with vinyl corner posts. or butt it into 2x stock or 5/4 stock at your corners along with trim around windows and doors if the brickmould is 1" thick or less. you have to have a minimum of 1 1/4" stock in order to have a proper edge to caulk to
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Windows on Wash (06-01-2013)
Old 05-31-2013, 06:47 PM   #6
I plan to have a 4" trim board on the top. I've looked into vinyl outside corners. How would you make that match the white trim board.. Vinyl vrs fiber cement trim
When your talking about butting it into. Your meaning having 5/4 trim board. 1 of the 2 ripped so it doesn't have to be mitered. Same with inside corners?
Old 05-31-2013, 08:57 PM   #7
Why would you use any Hardee trim? Just use vinyl.
I just can not imagine trying to mitre long pieces of vinyl.
It's hard on a blade, as the blade heats up it's going to wobble and the cuts going to want to wander off.
Old 05-31-2013, 09:25 PM   #8
747
registered
747's Avatar
Rewards Points: 534
Go with the metal outside corner trim. Not the plastic or vinyl or whatever its made out of. You can chip it when mowing the lawn. I did had to replace it.
Old 06-01-2013, 10:11 AM   #9
MJ Force's Avatar
Rewards Points: 150
No one mentioned Real Corner. I think it's like a Coneface product. The picture shows the basic corner however the ones for Hardie come with datto edges and are slightly thicker.
Regarding a 4" trim board along the top to finish the edge. IMO go with 3"(2 1/2") instead. 4" is too bulky and shows the angle too much.
MJ Force is offline   Reply With Quote
Old 06-01-2013, 10:12 AM   #10
Rewards Points: 626
5/4 primed spruce.
Nailbags is offline   Reply With Quote
Old 06-01-2013, 10:21 AM   #11
MJ Force's Avatar
Rewards Points: 150
Originally Posted by Nailbags
5/4 primed spruce.
If your talking about the Coneface product...I'm not sure if its spruce? It feels harder than spruce. Like Hemloch almost. Smells like Hemloch too.
Siding Options Vinyl vs. Fiber Cement obrien11j Building & Construction 35 09-26-2011 06:08 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
