What's The RIGHT Way To Do This? Slab/Siding Connection - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-28-2011, 07:21 PM   #1
What's the RIGHT way to do this? Slab/Siding connection
We moved into this house 4 years ago and since day one the area around the back wall has leaked. The wall was an "addon" to enclose a covered patio. 3 years ago we tried resloping the concrete in the area to help it drain away, but I think we worsened the situation. I'd like to know, if I had the chance to completely redo this area, how SHOULD it have been done? Grind the concrete down so it is sloped down, away from the house? Or bring the wall all the way out to the edge of the slab so water drains right off the siding?
What's the RIGHT way to do this?  Slab/Siding connection-p1010019.jpg
bigburb is offline   Reply With Quote
Old 05-28-2011, 07:33 PM   #2
kwikfishron's Avatar
Rewards Points: 576
Hey bigburb, there’s a few ways to deal with this. Could you post a picture of the entire wall?
kwikfishron is offline   Reply With Quote
Old 05-28-2011, 08:01 PM   #3
Surely. I took the doors out which is the reason for the tarp.
What's the RIGHT way to do this?  Slab/Siding connection-p1010021.jpg   What's the RIGHT way to do this?  Slab/Siding connection-p1010022.jpg
Old 05-28-2011, 08:19 PM   #4
rock16's Avatar
Have a Galv flashing made that goes up the wall 4'' slopes across the top of the concrete and goes down the face of the concrete 2''. Also have a door pan flashing made that incorporates this detail.
You will have to remove the bottom course of siding to tie this flashing into the WRB.
rock16 is offline   Reply With Quote
The Following User Says Thank You to rock16 For This Useful Post:
jomama45 (05-30-2011)
Old 05-28-2011, 08:35 PM   #5
Rewards Points: 576
The flashing as mentioned was my first thought and would work. I was hoping the wall wasn’t in as much of an exposed traffic area as it is.
If you don’t want it to look like a mistake you could build another wall out flush with the slab so the siding can lap over as it should be. The only interior issues would be wider window sills and door jamb.
Old 05-29-2011, 08:59 PM   #6
Ok well we are going the flashing route, it is cheaper and is going to take less time to accomplish (and less remove of existing windows). What should we seal the seams of the flashing with? Air duct mastic comes to mind, because we can slather it on rather liberally, but I'm not sure if its waterproof or appropriate for this situation.
Old 05-29-2011, 09:10 PM   #7
rock16's Avatar
This is good for your application:
Old 05-29-2011, 09:17 PM   #8
Hm it seems my local home depot doesn't stock the 15LM, all I see is SikaFlex SL Self leveling sealant, Sikaflex concrete sealant, Sikaflex mortar sealant, and Sikaflex construction sealant.
Old 05-29-2011, 09:20 PM   #9
rock16's Avatar
I believe the concrete sealant is the HD version of 15lm. Make sure it is polyurathane.
The construction sealant should be 1A (wrong app)
Old 05-29-2011, 09:22 PM   #10
yes it is poly, thanks so much for your help.
Old 05-29-2011, 09:24 PM   #11
rock16's Avatar
Good luck
Old 05-31-2011, 07:37 PM   #12
Thanks, we successfully built the entire thing, flashing and integrated door pan. We're in a severe drought here so who knows when it'll get tested, thanks for the advice!
Old 06-01-2011, 08:02 PM   #13
Tom Struble's Avatar
Rewards Points: 2,002
the fc panel should be elevated off the concrete 2'' min
Tom Struble is offline   Reply With Quote
Old 06-01-2011, 10:04 PM   #14
Even if I use hardie?
Dripping washing machine connection icespide Plumbing 4 11-11-2010 08:41 PM
3 way switch with pass through power connection issue ccmbee Electrical 2 09-28-2010 02:38 PM
Water softener connection question Aldyrin Plumbing 1 09-22-2010 09:30 PM
gas dryer connection question rvegab00 Plumbing 7 12-07-2009 10:53 AM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 06:10 AM
