What's Causing This? And Is It A Major Issue? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-04-2012, 03:34 PM   #1
Question
What's causing this? And is it a major issue?
I'm looking at a house and most of the walls have this:
The house has not been occupied for a while.....
Is this a major issue?
lowspeed is offline   Reply With Quote
Old 12-04-2012, 04:13 PM   #2
Rewards Points: 3,130
Looks like surface mold to me. A major issue? Depends on if it's inside the walls.
Old 12-04-2012, 04:17 PM   #3
How do you check ?
Cut a piece of the wall ? What if that's not a possibility ?
Old 12-04-2012, 04:46 PM   #4
Rewards Points: 502
What are we looking at? And whereabouts on the house is it (whatever 'it' is)?
tony.g is offline   Reply With Quote
Old 12-04-2012, 04:54 PM   #5
Rewards Points: 12,882
If there not willing to let you find out just how bad it is then they just did you a favor.
Walk away and find a differant house to by.
Mold issues can get expencive real quick.
Old 12-04-2012, 04:59 PM   #6
the photo is of a bedroom.
It's an auction property.
Old 12-04-2012, 07:28 PM   #7
Civil Engineer
Rewards Points: 4,526
That looks like mold, as others have said. Since this is an auction house, are you suggesting that it will be impossible to perform a detailed investigation of the property prior to bidding? If so, I would strongly consider purchasing a different property. Mold always requires moisture, relatively warm temperature, and a food source. The wall is the food source, but where is the water coming from? That is a question I would want a definitive answer to before I put up hard cash for a property.
Old 12-04-2012, 07:36 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 852
I think Daniel is being nice.
The fact that your asking means you really have no idea of what your getting into. Translation....don't buy it.....your way in over your head.
Now....with that said....please stick around....all of us were in your shoes at one time....you just don't want to make the mistake some (many) of us have made by taking on more than we should.
Old 12-05-2012, 03:47 PM   #9
Rewards Points: 150
Looks like moisture problem... Do you have a better choice amongst the auction properties?
oodssoo is offline   Reply With Quote
Old 12-05-2012, 04:49 PM   #10
I'm going against the grain and say go for it...BUT that hinges on some questions.
This wall is it an exterior wall or interior? Is there a bathroom or kitchen next to it? Is it a basement, 1st floor, attic level? Is it above a garage? Depending on the answers to this questions it may just be oil based stain under a coat of paint. I had this type looking stain on my attic and had mold and lead testing done (EPA requirement for foreclosures) and it turned out to just be oil based stain that got there somehow. I had to use two coats of offwhite primer and a coat of white paint to cover it.
rebelranger is offline   Reply With Quote
