What's The Best Way To Remove Plaster/Lath Walls And Replace With Drywall - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Poll: Replace Plaster with Drywall and Insulation or Leave Plaster walls and pay for repair
Poll Options
Old 02-14-2011, 11:04 AM   #31
Originally Posted by psubaron View Post
Also, does anyone have experience with a drywall hoist/lift which holds it against the ceiling while a person screws it in? Is it truly a one person job or does it require two people.
Thanks.
I've done it easily with 8' sheets and struggled with 12'. Get a helper. While he's screwing in the first sheet, you're cutting and measuring the 2nd
mrgins is offline   Reply With Quote
Old 02-14-2011, 11:20 AM   #32
SteelToes's Avatar
Rewards Points: 150
Be careful with a roll out dumpster , not a best thing to have on a black top driveway in the summer months.
In addition to fix the damaged plaster you need to remove all of the lose stuff and use a BASECOAT over the lath and finish of with gauging plaster.
Google red top or structo gauge.
Muding over crumbling plaster with durabond is only going to last as long as the surrounding plaster does.
SteelToes is offline   Reply With Quote
Tags
drywall , insulation , lath , plaster wall
Remove half walls & replace with wood railing/balusters jjgoss Remodeling 3 06-29-2010 08:05 PM
Roof Leaking - Do I Need to Replace Drywall? dombrorj General DIY Discussions 5 06-21-2010 05:10 PM
water damage remove mold & repair or replace drywall homerepair1 Drywall & Plaster 2 02-22-2009 10:00 AM
Replace exterior walls or build false walls Medic507 Carpentry 3 11-12-2008 09:48 AM
When to replace wet drywall ? summers Drywall & Plaster 4 10-07-2008 08:41 AM
