What's This Beam For? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 06:28 PM   #1
GBunny
Rewards Points: 71
What's this beam for?
We're renovating a bathroom and found this beam hidden under a piece of metal. This was originally a large bathroom was divided to create an ensuite bathroom.
Is it possible this was the top of the original shower wall where the taps were attached? Why else would it hang lower than the drywall?
The contractor wants to cut it out and put drywall over it and it just want to make sure it's not supporting anything else.
GBunny is offline   Reply With Quote
Old 04-19-2011, 06:39 PM   #2
Not so new
12penny's Avatar
Rewards Points: 520
Well...not being there....and not having a picture....its near impossible to tell.
12penny is offline   Reply With Quote
Old 04-19-2011, 06:55 PM   #3
DIY staff
Rewards Points: 7,174
Pictures---attic and room--Mike---
Old 04-19-2011, 07:12 PM   #4
GBunny
Rewards Points: 71
Picture attached
Sorry - thought I'd already attached the pictures. The current shower taps are on the other side of the wall where the lights are located.
Old 04-19-2011, 07:14 PM   #5
GBunny
Rewards Points: 71
Here's the other picture
Here is the other picture.
Old 04-19-2011, 11:18 PM   #6
Registered User
Rewards Points: 5,516
Need an attic picture to see if it is a beam or a top plate. 5' away....
Gary
Old 04-20-2011, 08:19 AM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
It looks like a nailer to me but to be safe a picture from above would be of help like Gary said.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 04-20-2011, 11:59 AM   #8
Registered User
Not a beam because of the bent nail from above. Must be a top plate with a backer for drywall nailed to it still supporting both side of ceiling. See the nail end poking through in first pic at left side, but what if anything is above?
It was a wall, supply lines would usually come from below. Possibly have blown-in insulation above, hence the reason why it wasn't removed?
Picture from attic.....
Gary
Old 04-20-2011, 02:02 PM   #9
Tizzer's Avatar
Rewards Points: 460
I wonder why you're asking this here. This contractor, he doesn't know how to check this?
Either through attic access or cutting a hole in the sheetrock near that plate will tell.
Tizzer is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 08:38 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 12:08 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
