What Would Be The Height Of This Building - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-16-2011, 06:54 PM   #1
What would be the height of this building
12X12 building with a 12/12 roof slope, Assume a 7 foot high door opening and a two foot overhang.
ConfusedinPA is offline   Reply With Quote
Old 07-16-2011, 07:42 PM   #2
NACE Coating Inspector
mustangmike3789's Avatar
now im confused. what in the hell are you talking about.
mustangmike3789 is offline   Reply With Quote
The Following User Says Thank You to mustangmike3789 For This Useful Post:
gregzoll (07-16-2011)
Old 07-16-2011, 08:05 PM   #3
Rewards Points: 5,336
13 feet
Ron
B. Franklin 1759
Old 07-16-2011, 08:08 PM   #4
Framing Contractor
Rewards Points: 120
Originally Posted by Ron6519 View Post
13 feet
No seat cut on the rafter? No header over the door? Then again, if the door is on the gable end, this building could be shorter than 13'
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
mustangmike3789 (07-16-2011)
Old 07-16-2011, 08:23 PM   #5
Go ahead and crush my little heart.
Ron
B. Franklin 1759
Old 07-16-2011, 08:36 PM   #6
Old School
Willie T's Avatar
What if it has a loft? Then ya gotta go figure for the floor above.
Might even be an "A" Frame sitting on the ground.
Willie T
Old 07-16-2011, 08:40 PM   #7
kwikfishron's Avatar
Rewards Points: 610
15' 2" from grade with 2x6 rafters.
kwikfishron is online now   Reply With Quote
Old 07-16-2011, 08:43 PM   #8
Rewards Points: 6,652
Someone has homework, and wants the Intertubes to do it for them.
Old 07-16-2011, 09:57 PM   #9
Registered User
Rewards Points: 5,516
Shed roof?
Gable/hip roof?
Gambrel roof?
All different heights.
Now.... if two trains were traveling.....
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
BigJim (07-17-2011)
Old 07-16-2011, 10:11 PM   #10
Framing Contractor
Rewards Points: 120
If it was an A frame sitting on the ground, you could not fit a door in. He said 12'x12' which would make it only 6' height if it was a 12/12 pitch.
Old 07-16-2011, 10:33 PM   #11
he doesnt say how tall the walls are so how can you figure the height of the building?? the roof if a gable or hip would add 6 feet to the height but without the wall dimensions you cant get an answer.
Old 07-16-2011, 11:04 PM   #12
Learning by Doing
Leah Frances's Avatar
This is the WRONG place to try and get ONE answer.
I say that the answer is 17. The door opening is supposed to be 7 foot, but what if I want my door of my A-frame mounted 8 feet off the ground because of polar bears.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-16-2011, 11:10 PM   #13
What if it had eyebrow dormers over the door.
Old 07-16-2011, 11:15 PM   #14
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
My guess is 14' 9"
Andy.
AndyGump is offline   Reply With Quote
Old 07-17-2011, 12:10 AM   #15
the OP did not say it was an A frame. need more info from OP to answer
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
getting a building permit after construction is done ChrisJJ General DIY Discussions 22 08-15-2012 08:18 AM
Old Building problems jake62 Building & Construction 5 08-20-2010 08:32 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
