What In The World Are These Holes For??? - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-18-2012, 09:24 PM   #31
Superswid's Avatar
Originally Posted by Total Tool View Post
How much water flows out and when does it flow?
I'm not sure becasue it only happened because it was raining and I didn't go outside when it was raining. No other time has this occurred and so I will for sure go out and check it out when/if it rains heavy again. But there isn't any other situation that causes this.
Superswid is offline   Reply With Quote
Old 03-18-2012, 11:05 PM   #32
holes ?
Originally Posted by Superswid View Post
What don't you like, the holes themselves or the fact that there is a water mark appearing to be coming from them? And who would I call to have this looked at, a roofer?
they look like holes in framing called bird blocks air holes , or vents for air flow .
shockme123 is offline   Reply With Quote
Old 03-19-2012, 02:38 AM   #33
Superswid's Avatar
I looked up in the attic again and there's no sign of moisture near that area at all. I just wish I knew what the water mark was about on the outside. One of my neighbors has the same water mark, yet his frame doesn't ahve these holes. I just don't get it.
Old 03-21-2012, 12:04 AM   #34
Registered User
Rewards Points: 4,924
Here's a stretch...... prevailing wind on other side of house letting in moist, humid air through the soffit, rolling across attic, condensing when trying the squeeze through under-vented this side of house, with no ridge vents.... Bird-block gets saturated, runs down- wetting the stucco... Condenses there because other side is in full sun- this side cooler walls (first condensing surface): http://www.buildingscience.com/docum...bout-diffusion
Gary
P.S.- well, never mind, just read previous post.....LOL.
Old 03-21-2012, 04:14 PM   #35
Just a DIY guy
Originally Posted by AndyWRS View Post
Looks a lot like eve / soffit venting to me. That Hip to facsia tie in up on the roof could be leaking...and it just happens to soaking the stucco in that location.
Looks like the typical Southern California eve vent to me. Check around the house, do you see it in other areas ? I am thinking roof leak and its just a coincidence the stucco wall is wet below the eve vents in fire block.
That's my thought too. But it is an odd place for water to show up.
A lot of people are talking about bathroom condensation, but here in So Cal, the outside air is dry and fairly warm, so condensation is minimal.
M3 Pete is offline   Reply With Quote
Old 03-21-2012, 06:28 PM   #36
Metal Roofing
Rewards Points: 600
The fact the water is showing up around the vented fire blocks may just be a coincidence. Because it is an unusual spot for a leak of any type i would suspect the roof first also because the op says only when it rains does this appear.
AndyWRS is offline   Reply With Quote
Old 03-21-2012, 06:53 PM   #37
Rewards Points: 2,512
Take a hose up on the roof in the area above the leak and let the water run for 20 minutes.....see if water leaks from the underside of the overhang
hammerlane is offline   Reply With Quote
Old 03-21-2012, 07:43 PM   #38
Tom Struble's Avatar
Rewards Points: 2,002
i don't think the homeowner should be getting on his tiled roof...with a hose
Tom Struble is offline   Reply With Quote
Old 03-21-2012, 07:50 PM   #39
Rewards Points: 252
The edge of the high roof seems to line up with the water mark. I don't know how that roof slopes but I would bet it has something to do with that.
shazapple is offline   Reply With Quote
Old 03-21-2012, 07:51 PM   #40
Metal Roofing
Rewards Points: 600
Agreed.
Looks like a lot of roofs in OC, if thats the case i would offer to look at it no charge. I work for a roofing company in OC.
A lot of roofs in So CA are a single layer of 30lb under heavy tile like that, no idea how they got away with it.
Old 03-21-2012, 08:07 PM   #41
The homeowner should consider your thoughts vs. trying to find the source of the leak
Old 03-22-2012, 03:51 PM   #42
Superswid's Avatar
Well again, the same thing happened on the other side where there's no b-room
Which seems strangeley coincidental.
Old 03-22-2012, 07:07 PM   #43
Rewards Points: 29
As others have noted, they are definitly soffit vent holes - california style My house has them too (LA Area).
I've also seen similar water marks on the stucco certain in areas around my home after the rains. It often appears on the side of the house that the wind was blowing from. It seems to concentrate in some places - like you are seeing. Perhaps the stucco is more porus in these areas? - or maybe there is less insulation in the wall there so there is more condensation on the stucco? I don't know for sure, but I can tell you I've seen at my place too but it hasn't caused any problems - house is 11 years old.
fritzycat1 is offline   Reply With Quote
Old 03-22-2012, 10:14 PM   #44
none that you know of,stucco can be sneaky stuff sometimes
Old 03-22-2012, 10:49 PM   #45
Superswid's Avatar
Interesting, thanks for the input.
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 11:32 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Series of holes in periphery of basement slab BalowskiJ Building & Construction 4 04-18-2011 02:49 PM
Alternatives for fixing holes in tile roof felt Squash_Pro Roofing/Siding 4 05-13-2010 07:20 PM
Drilling Multiple Holes in Studs rjschwar Building & Construction 6 01-27-2010 02:05 PM
