What In The World Are These Holes For??? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-18-2012, 04:23 PM   #16
Tom Struble's Avatar
Rewards Points: 2,002
well how do we know water is also not going behind the wall surface?,i guess a roofer/sider that knows how to work around tile and stucco
Tom Struble is offline   Reply With Quote
Old 03-18-2012, 04:24 PM   #17
is that a bathroom wall??
Old 03-18-2012, 04:32 PM   #18
Metal Roofing
Rewards Points: 600
Looks a lot like eve / soffit venting to me. That Hip to facsia tie in up on the roof could be leaking...and it just happens to soaking the stucco in that location.
Looks like the typical Southern California eve vent to me. Check around the house, do you see it in other areas ? I am thinking roof leak and its just a coincidence the stucco wall is wet below the eve vents in fire block.
AndyWRS is offline   Reply With Quote
Old 03-18-2012, 04:41 PM   #19
Superswid's Avatar
It is a bathroom wall. However the right side face has the same holes but its a stairwell wall. There is a watermar on that side as well in the same area, yet slightly offset from the holes.
Superswid is offline   Reply With Quote
Old 03-18-2012, 04:43 PM   #20
he says there are other homes with the same thingnow thats one cowinkydink
Old 03-18-2012, 04:44 PM   #21
where is the bathroom fan vent located?
Old 03-18-2012, 04:45 PM   #22
Superswid's Avatar
No vent in this particular bathroom.
Old 03-18-2012, 04:48 PM   #23
shower/ tub in it?
Old 03-18-2012, 04:52 PM   #24
Superswid's Avatar
shower/ tub in it?
Yes righton the inside of that wall. On the other side, where the same phenomenon is occuring, its a stairwell.
Old 03-18-2012, 04:55 PM   #25
that may be your problem
Old 03-18-2012, 05:27 PM   #26
Superswid's Avatar
But the same issue is on the other side of house where there is no bathroom. Also, it seems like I is related to the rain and not from plumbing and no sign of water stain on inside of house.
Old 03-18-2012, 05:49 PM   #27
JOATMON
ddawg16's Avatar
Rewards Points: 818
Bird house?
ddawg16 is online now   Reply With Quote
Old 03-18-2012, 06:17 PM   #28
your right more thorough investigation is needed,but a working bathroom pumps out alot of moisture and unless you leave the bathroom window open it could be migrating into the attic space thats shared with the stairwell,why it manifest itself by the holes? i don't really know,possibly being caught by a vapor barrier
Old 03-18-2012, 09:02 PM   #29
Rewards Points: 81
How much water flows out and when does it flow?
Total Tool is offline   Reply With Quote
Old 03-18-2012, 09:06 PM   #30
joed's Avatar
Rewards Points: 11,576
Blow some smoke into them and see where it comes out.
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 11:32 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Series of holes in periphery of basement slab BalowskiJ Building & Construction 4 04-18-2011 02:49 PM
Alternatives for fixing holes in tile roof felt Squash_Pro Roofing/Siding 4 05-13-2010 07:20 PM
Drilling Multiple Holes in Studs rjschwar Building & Construction 6 01-27-2010 02:05 PM
