What To Use For Hardi Joint Flashing? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-02-2009, 10:25 PM   #1
Rewards Points: 45
What to use for Hardi joint flashing?
I know that I can't use aluminum flashing on cement products but what is recommended as a long lasting joint flashing for the area where Hardiplank siding panels meet; will rigid PVC last as long as the siding or will it get brittle and crack over time?
kooshball is offline   Reply With Quote
Old 12-03-2009, 12:06 AM   #2
dIYHell
Rewards Points: 150
Actually you can use metal flashing for hardipanels Fry Reglet makes them http://fryreglet.com/products-revealpaneltrim.htm. I did a project with them and it produces a very cool modern look. Its a bit tricky because you don't install the panels then install the trim to cover inaccuracies you need to install the reglets at the same time you install the panels. your cuts need to be very accurate and you need to counter synch and screw not nail the panels.
If your looking for trim to place on after the fact I don't know why you can use aluminum flashing other than it would be hard to install to look nice, never heard of not using aluminun with cementous material. you could also use wood trim?
rocketdoctor is online now   Reply With Quote
Old 12-03-2009, 03:30 PM   #3
Registered User
Rewards Points: 5,514
I'd check with your local building department. Also, pre-drill the face or blind nails at joints and prime the ends. OR, put all factory ends at butt joints. They may say 30# paper. Remember this is a porous cement product that will wick water readily.
Be safe, Gary
Old 12-04-2009, 02:17 PM   #4
Next Time...New Build
Rewards Points: 150
We always factory butted the seams as GBR mentioned and place strips of 15# felt behind the seams to hide the white of the Tyvek in case of some shrinkage of the panels. These were the painted panels that came finished directly from the factory with the chosen color.
However, in the corners and the drip above windows we bent up alumininum and butted the panels directly to that without an issue.
This was in the northeast for a house directly on a lake that gets exposed to driving rains as well as some pretty good snowfall. We did this quite a few years ago and have not had any complaints.
RickyBobby is offline   Reply With Quote
Old 12-04-2009, 04:58 PM   #5
Registered User
Use the right application....... http://www.fortifiber.com/pdf/fortif...sk_vs_felt.pdf
Be safe, Gary
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Need roofing tips! dc4nomore Roofing/Siding 114 07-03-2009 07:01 AM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 10:00 PM
