Old 10-31-2008, 01:04 AM   #1
What to use between sill plate and concrete base?
What would be best to use as a sealer between the sill plate and a concrete base? This would be to prevent air leaks and stop the bugs getting thru! My local Lumber Yard guy says use ready-made black tar which does not disintegrate over time and is cheap. He says standard caulk will deteriorate over time with bugs/bacteria eating it.
From experienced framers..what is best?
Elecman is offline   Reply With Quote
Old 10-31-2008, 06:56 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I've heard different things from different parts of the country. I will tell you what I have been accustomed to using over the years, and what others use, in my region; The standard material is "sill foam", or "sill seal". Examples:
http://www.building.dow.com/na/res-u.../sill_seal.htm
http://www.lowes.com/lowes/lkn?actio...404&lpage=none
- Build Well -
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Half Lap Sill Plate Join Clutchcargo Building & Construction 3 09-05-2008 04:07 PM
Rotted sill plate replacement help handyd123 Building & Construction 2 08-25-2008 07:02 PM
Sill plate and pre-hung door sithappens Building & Construction 4 01-27-2008 07:18 AM
Replacing a concrete tube lally Bob2468 Building & Construction 5 05-08-2007 09:27 AM
