What Type / Size Screws For Subloor Project... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-17-2008, 02:42 PM   #1
Stretch
What type / size screws for subloor project...
What type / size / length screw would you recommend for the following:
1) 3/4" plywood subfloor to joist (along with liquid nails).
2) 3/4" underlayment to subfloor.
3) 1/4" hardiboard to underlayment.
Also is there a "chart" for recommended pilot hole / drill bit size for each size screw? That would be handy too!
Thanks in advance...y'all
scheenstra is offline   Reply With Quote
Old 05-17-2008, 08:22 PM   #2
remodeling pro
The accepted standard is a fastener length three times the thickness of the material being fastened, so that the fastener penetrates the joist 2/3 of it's length. It is not necesary to drill pilot holes for these applications, as the screws will countersink themselves in the wood, and if you use screws made for tile backer board, they have little cutting nibs on the bottom of the head for this purpose. The backer board can also be nailed down with hot galvanized roofing nails.
troubleseeker is offline   Reply With Quote
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Wire size and type in Rigid Metal Conduit Al the Diy guy Electrical 5 02-05-2008 08:31 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
Plumbing type and size marlenecapps@cox.net Plumbing 2 10-14-2005 11:42 AM
