What Type Of Nails We Should Use For Sheathing Roof And Walls Of A Shed? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-18-2012, 03:22 PM   #16
Rewards Points: 636
no buy a 9' or more likely to find 10' 2x4 and cut it to length.
i still will suggest the rubber roof with the extra 2x4 on top to give fall as best plan
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-18-2012, 03:26 PM   #17
Rewards Points: 71
Some confusion here...front wall is 15 feet long and top plate also be 15 feet long and I have to put something on top plate of front wall to create a slope..
I dont understand why are you saying buy 10 feet 2x4 and cut to length? ..10 feet is already smaller than 15"
vikasintl is offline   Reply With Quote
Old 05-18-2012, 03:38 PM   #18
Rewards Points: 636
as you posted in #6 you were going to use 8 ' studs so use them on one side and take 10 foot studs and cut them to 8'8" for other side to get your 8" fall
Old 05-18-2012, 03:59 PM   #19
Rewards Points: 71
Question
Well that can be one option to do it but if I cut to 8.8' than rafter would be another 3.5 inches so total would be more than 10 feet ...
and that will not be pitch ..pitch would still be higher because of overhang...front overhang would be about 2 feet..correct me if am wrong?
I am really confused here..don't know what is the best way...
1 one option is increase the height on front wall by buying longer 2x4 and cut to desire height..i.e 8.4' something..
2. other option is cut the back wall height to 7.6' and front height to 8.2'
( I would not choose this option because its double labor and shed height will be decreased overall.)
3. third option is don't cut any lumber on front or back just stack 2x4 on top of top plate to get desired slope...
Please suggest what is the best solution?
Old 05-18-2012, 04:10 PM   #20
Rewards Points: 71
Question
Thanks again but if I cut them at 8.8 total on that front wall would be 8.8 feet +3 inches (top and bottom plate)+1 foot(floor) = 9 feet and 11 inches but like I said I will have a overhang of 2 feet so if it will 9 ft. and 11 inch on top plate..on over hang it will be more than that which would be more than 10 feet...I hope you will get my point/problem..
Old 05-18-2012, 04:29 PM   #21
Rewards Points: 636
can you take a pic of what you have and then draw and post what you want. i am not seeing the same picture in my head as what you have posted i am sure that is why there is confusion
Old 05-18-2012, 10:52 PM   #22
Rewards Points: 71
as soon as I get my camera back I will upload pic and we go from there..thanks for all sharing and advice..
Tags
roof , sheathing , siding , walls
Attaching shed style roof between existing buildings. Chutzie Building & Construction 4 07-26-2011 05:16 PM
Newbie roofing a shed with a gambrel roof tomseeley Roofing/Siding 2 09-08-2010 01:11 PM
shed with block walls - rehab kirkpala Building & Construction 8 07-23-2009 11:21 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 11:31 PM
