Old 05-07-2010, 12:06 PM   #1
Just call me Andrew
What type of insulation?
I am re-insulating the ceiling in my second floor bathroom. There is no attic above the bathroom, this is a finished attic. I will put proper vents on the underside of the roof (new flat roof). Should I used faced or unfaced insulation in this scenario? The old insulation was faced and stuffed right on the underside of the roof, and there was a lot of moisture and some mold up there. Luckily, I caught it before the wood rotted out.
I will be installing a good exhaust fan as well. Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 05-07-2010, 02:44 PM   #2
If there's conditioned space right above the bathroom, why are you insulating the ceiling? Or is this a case where part of the ceiling is over area outside the conditioned area, such as behind a kneewall in the attic?
Or, is the bathroom in the finished attic?
RoyalAcresRod is offline   Reply With Quote
Old 05-07-2010, 02:56 PM   #3
Just call me Andrew
It's a finished attic. I am thinking unfaced insulation with plastic on the warm side of the insulation.
Andrew
Old 05-07-2010, 03:43 PM   #4
I think that is an excellent way to go in a warm and humid room on an exterior plane. Be sure to tape all joints in the vapor barrier with a good "tuck tape"
rod
Old 05-07-2010, 08:40 PM   #5
Just call me Andrew
I can't seem to find Tuck tape. Is foil tape use for ducts sufficient? I will also have a good panasonic exhaust fan and moisture-resistant drywall.
Andrew
Old 05-07-2010, 10:45 PM   #6
"tuck" tape is a generic term. Someone may correct me, but I believe Tvyek tape works well is this application. It's usaully about $12 a roll at he Big Box stores
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 10:57 AM
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 09:19 AM
2x4 Exterior Wall Insulation stubits Building & Construction 4 03-19-2009 08:03 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
