What Type Drainage Pipe To Use On A Gravel Way - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-30-2008, 10:14 AM   #1
what type drainage pipe to use on a gravel way
i have a gravel driveway that slopes to my garge where the garge and driveway met their is a valley where the water is collecting i have atranch there to devert the water . but that won't last long because we drive over it to get into the garge, what kind of pipe should i use and do i need pea gravle for it or can i use that sleve for the coragated pipe? and should i put a drain great on top to help with the drainge any sugestions.
markstrt339 is offline   Reply With Quote
Old 11-30-2008, 04:30 PM   #2
being that its gravel, I'd try to fill in the valley with more stone, to hold water I figure its packed down pretty good. also, take a look to each side of the garage to see if maybe you can landscape some to move the water away. the flex pipe with the wrap is cheap enough, can't hurt to try that, put down, cover with some stone.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Will gravel around house help drainage? evolve Landscaping & Lawn Care 9 05-30-2011 02:23 PM
Building a soffit around a drainage pipe along the wall ssudha17 Building & Construction 12 10-04-2008 03:18 PM
Heavy-duty roots in ground drainage pipe proofer Plumbing 11 08-06-2008 04:42 PM
Drainage issue and need suggestion on type of grass golfer2b Landscaping & Lawn Care 9 03-24-2008 07:38 PM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 07:53 PM
