What Are These On My Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-18-2012, 09:29 AM   #1
Rewards Points: 97
What are these on my wall?
I just found these this morning as the morning light played in from my screen door. How do I get rid of them?
edta1 is offline   Reply With Quote
Old 11-18-2012, 10:01 AM   #2
Rewards Points: 6,652
Just a bad mud job. Sand down, fill any spots that open up, then sand, prime, then paint. If you drag it out, it can take the whole weekend, so you have an excuse for not doing anything else.
Old 11-18-2012, 10:12 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
I'm going to say nail pops.....that is assuming they used nails to attach your drywall.
Sort of common when the temp changes.
Scratch the mud off one hole....confirm that it is a nail. If so, if was me, I would pull out the nail and replace it with a drywall screw. The patch job is basically the same.
Old 11-18-2012, 11:17 AM   #4
joed's Avatar
Rewards Points: 12,442
Looks like nail pops to me as well.
Old 11-19-2012, 12:21 AM   #5
I vote for 3 nail pops and one chunk of mud that didn't get sanded out.
spotco2 is offline   Reply With Quote
Old 11-19-2012, 01:14 AM   #6
Rewards Points: 2,212
How far apart are they side to side. if about 16" or 24" then probably nail pops.
The center one may be nail pop of a glob in the paint or bad mudding.
mae-ling is offline   Reply With Quote
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 07:49 PM
Removing a portion of a load bearing wall WFCC Carpentry 3 09-17-2011 06:17 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
