What Are These 2X4s Nailed Above This Top Plate (bathroom Wall) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-29-2011, 11:08 AM   #1
Rewards Points: 682
What are these 2X4s nailed above this top plate (bathroom wall)
I was in a dark, dusty attic planning on how to run a wire to install a light fixture. I was hoping to drill thru the top plate on the wall and run the wire down between the drywall sections. But all along the top plate they had fixed 2X4s, narrow side down, so I would have had to drill thru 5 inches of wood instead of 1.5 inches I was hoping for.
My question is, why would they do something like this?
darsunt is offline   Reply With Quote
Old 01-29-2011, 04:27 PM   #2
Rewards Points: 5,336
It seemed like a good solution at the time.
Ron
Old 01-29-2011, 04:34 PM   #3
Carpenter
dtsman's Avatar
Maybe someone ordered the wrong length boards for the wall studs, so they did that to add another 3.5". ? ?
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Old 01-29-2011, 05:51 PM   #4
Buy a longer dill bit?
mrgins is offline   Reply With Quote
bathroom sink & wall dknarnd Remodeling 1 01-24-2010 10:56 PM
brick wall in the bathroom kjco Remodeling 5 05-10-2009 11:32 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Bathroom - tub liner, wall system, etc.??? jlaam Remodeling 7 09-30-2007 08:25 AM
