What Span Needs Bridging - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-19-2008, 08:08 PM   #1
Rewards Points: 274
what span needs bridging
what length span of floor joists requires bridging blocks, 2" x 10" - 16" O.C.? Thanks
ugabulldog is offline   Reply With Quote
Old 10-19-2008, 08:18 PM   #2
Theres more then one way.
iMisspell's Avatar
Rewards Points: 150
Just asked something simulare the other day for 11-7/8 TGI joists.
Bridge spacing for 11 7/8 TGI's
iMisspell is offline   Reply With Quote
Old 10-19-2008, 10:17 PM   #3
Registered User
Termite's Avatar
There isn't a requirement, per se. I'd certainly do it anyway. A couple runs of bridging on an average span will help make the floor less bouncy.
Old 10-19-2008, 11:05 PM   #4
Drywall contractor
Rewards Points: 1,070
I personally would use bridging on spans over 8'. Don't know if or what code may be. As KC said, gives a much more solid job.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-20-2008, 07:34 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
I was under the impression that any joist with an open span over 8' needed blocking or bridging. Stud walls over certain heights also require it. I always thought it was a code requirement. Termite?
Old 10-20-2008, 07:44 AM   #6
the Musigician
DangerMouse's Avatar
my architech/engineer has me drawn up to use end blocks or hangers (i'll use hangers) on 15' 2x12 spans, with solid 2x12 bridging through center. inspector ok'd it.
DM
Old 10-20-2008, 09:37 AM   #7
Registered User
Termite's Avatar
Sort of true. IRC 507.1 requires bridging for joists exceeding nominal 2x12 every 8'. 2x12 and down do not require bridging by code.
Stud wall rack bracing is a whole different animal for a different thread.
Old 10-20-2008, 09:00 PM   #8
Rewards Points: 274
thanks all, I went ahead and put bridging, it was a 10' span
Platform across a 9 foot span Hogan-s Carpentry 1 09-19-2008 07:46 AM
pole barn ? @ span length & size lumber req.. ugabulldog Building & Construction 3 09-11-2008 01:07 PM
open span under hipped roof..... SickPuppy Carpentry 3 06-06-2008 11:24 AM
Max span for 4x8 header? MusicMan_234 Building & Construction 2 05-29-2008 12:17 PM
joist span? apowens Carpentry 17 05-04-2007 07:54 AM
