What Sort Of Blocking Should I Install Behind Drywall-CBU Seam? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 12:04 PM   #1
Rewards Points: 508
What sort of blocking should I install behind drywall-CBU seam?
This question seems like it should be fairly common, but I can't find a related thread. The CBU from my shower extend about 4 inches into a stud bay. What sort of blocking should I install to support this vertical seam? Toe nailing in a 4" gap is pretty hard, so I would prefer to not add another stud in that space.
benjamincall is offline   Reply With Quote
Old 02-05-2011, 12:10 PM   #2
Rewards Points: 5,336
Put in another stud or block it every 12 " or 16" up the wall.
Ron
Old 02-05-2011, 12:48 PM   #3
Rewards Points: 508
How about using 2x8s? What about a strip of plywood or OSB the full length of the stud bay?
Old 02-05-2011, 01:39 PM   #4
Blocking is blocking. You can use any "2x " material you want. The point is that it's rigid. No stud bay length of sheet goods would be my choice.
Ron
Old 02-05-2011, 01:42 PM   #5
Framing Contractor
Nail a 2x6 flat into the last stud and into the shoe and top plate.
Joe Carola
Joe Carola is offline   Reply With Quote
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 09:02 AM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
drywall seam issues onemeek Drywall & Plaster 16 04-06-2009 04:39 PM
Drywall Mudding Challenge: Seam vs. Tapered Corner cjakins Drywall & Plaster 3 03-10-2009 12:41 PM
bathtub install matjone Plumbing 3 01-03-2008 05:51 PM
