What Size And Type Window Over Tub/shower? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-30-2010, 09:27 PM   #1
Rewards Points: 562
what size and type window over tub/shower?
Like a million other older houses this one has tub on outside wall with a 30" wide and 38" high window now which happens to look onto a busy street.
Eventually it is going to get a ceramic tile surround on walls and a shower made out of this 'tub only' now. and yes I will use plastic vapor barrier,cement board then dittra or red guard. will slant what ever window sill on a 45* slant so no water can sit there, nor used for storage that might crack glass.
For now doing windows, doors, and siding on exterior. Want a window that will be above 6' or so to prevent view from outside(maybe few inches less okay) and stay above water line as much as possible. Vinyl to take moisture and indirect spray and opening for air etc.
What style and stock size available would work best?? How short do windows come?(standard 8' ceilings)
4just1don is offline   Reply With Quote
Old 06-30-2010, 09:56 PM   #2
jlhaslip's Avatar
Rewards Points: 2,132
check out glass block
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 06-30-2010, 11:31 PM   #3
Rewards Points: 562
never did glass blk. before,,,is it hard? thought a regular nailing fin vinyl window sounded easier
Old 07-01-2010, 06:26 AM   #4
Tom Struble's Avatar
Rewards Points: 2,002
you can have both
http://www.hy-lite.com/
Tom Struble is offline   Reply With Quote
Old 07-01-2010, 08:01 AM   #5
47_47's Avatar
Rewards Points: 58
Not an answer to your window question, but you realize that this will give you a double vapor barrier.
Handful of tub tiling questions
47_47 is offline   Reply With Quote
Old 07-01-2010, 08:59 AM   #6
Old School
Willie T's Avatar
I like to look outside as I shower, and also have ventilation. I installed a double hung window with white frosting (no shadow see-through). I lower the top section and leave the lower part closed. Watching the squirrels playing keeps showers from getting boring.
Willie T
Old 07-01-2010, 08:00 PM   #7
careful Willie,i hear they are fond of nuts
The Following User Says Thank You to Tom Struble For This Useful Post:
Willie T (07-02-2010)
Old 07-01-2010, 08:32 PM   #8
Rewards Points: 562
moisture vs vinyl
IF I put a all vinyl double hung window where the present wood one is. And a tension rod with a short plastic curtain over it for main direct spray. Will the vinyl window stand up to all the rest of the moisture????,,will it bleed excess water from the track to the outside??
Old 07-01-2010, 11:00 PM   #9
yes to both questions
Old 07-02-2010, 09:48 PM   #10
I have my doubts about glass block and moisture issues. What about a "Pella" or equal window that has blinds within the glazing unit. At least then you have an insulated window unit that also serves as a blind.
Just a thought
Bldg 2 Spec is offline   Reply With Quote
What size and type wire should I use? Iman Electrical 4 06-20-2010 01:57 AM
Size of Wire & type of wire agman Electrical 6 11-10-2009 08:13 PM
What size and type of nails to use keviadams General DIY Discussions 2 09-28-2009 12:25 PM
Nail size and Type ????? mjkpainting Carpentry 7 11-21-2008 02:06 AM
What type / size screws for subloor project... scheenstra Building & Construction 1 05-17-2008 08:22 PM
