What Size Trowel For 4 1/4 X 4 1/4 Tiles? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-21-2009, 11:01 AM   #1
Serious Do It Myselfer
what size trowel for 4 1/4 x 4 1/4 tiles?
I am doing a shower stall in 4 1/4 x 4 1/4" tiles (and smaller) on 1/2" cement board.
I have already started the first row applying the thinset with a notched trowel that has a small zig-zag tooth. The trowel has a label on it that says its for 6" and smaller tiles.
Everywhere I look on this site reccomends a 1/4 x 1/4 notch but I cant find anything related to my tile size.
What size is best for my tile size?
Jim W is offline   Reply With Quote
Old 06-21-2009, 11:22 AM   #2
The notch should be as thick as the tiles.
Mop in Hand is offline   Reply With Quote
Old 06-21-2009, 11:28 AM   #3
Darn it! Does that mean I have to start over? I know my tiles are at least 3/16 - the "V" notches are probably only 1/8 - The trowel was probably made for mastic - not thinset.
Old 06-21-2009, 11:47 AM   #4
V-notched trowels are mostly used for mastic or glues. If your not too far into the project, if it were mine I would start over. Did you use Redgaurd over your CBU? If not, I would highly recommend it.
Old 06-21-2009, 04:58 PM   #5
Rewards Points: 5,336
I don't think you have the correct trowel for ceramic tile. You're using a trowel for applying adhesive for a wood floor or sheet vinyl.
I've never seen an 1/8" notch for any ceramic tile. The smallest "V" notch for ceramic is 1/4"
The correct size trowel is listed on the bags of thinset or the pails of mastic.
Ron
Old 06-21-2009, 10:27 PM   #6
Thanks for all the help
This site is sooo useful
Jim
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
calking backer board to tub glassman General DIY Discussions 13 06-19-2008 09:41 PM
Trowel notch size 47_47 Flooring 2 12-10-2007 12:46 PM
What size trowel for 20" tiles? kemerick Flooring 9 10-09-2007 10:31 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
