What Size Steel Reinforcement? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-02-2013, 04:56 PM   #1
Rewards Points: 39
What size steel reinforcement?
We are about to close on a home and our inspection gave us a few points to fix. This is our first home, but I have some home DIY experience and tools.
In our basement, the inspector (a structural engineer) stated this notched floor joist should be reinforced with a piece of steel. The steel would bolt to the joist and should sit on the stone foundation.
How long and thick should the steel be? How much better would a piece of channel be over a piece of angle? Any additional repair suggestions?
KansasCity is offline   Reply With Quote
Old 06-02-2013, 05:03 PM   #2
Old School
Willie T's Avatar
Reinforced? Is there any unrotted wood to reinforce?
(This house is in Independence, right? )
Willie T
Old 06-02-2013, 05:08 PM   #3
Rewards Points: 6,652
I would not worry about it, since there is the one joist next to it, which is the supporting member. If you want to replace it, you can, but all the load is actually being carried by that one that is behind the white flex tubing.
If you want the Home Inspector/ex-fry/burger flipper to be happy spend some money to pay for a Structural Engineer to come in, also along with a real electrician, not one that works for some company with the largest advertisement in the Yellow pages and prettiest trucks, since most have less than four years of experience, that they send on these kind of jobs to look stuff over.
Personally I would be more concerned about that Knob & Tube first off, then the one beam that again is not what is carrying the load, the other one in back is.
Old 06-02-2013, 05:17 PM   #4
Rewards Points: 39
Its truly in Kansas City (oh the Independence joke).
The joist isn't completely rotted, the picture makes it look worse. It was painted at some point, then notched, then wet, so it looks bad.
If it doesn't seem like a big deal, I won't worry about it right away. When we move in, I will take pictures and measurements.
The knob and tube isn't live anymore, someone was just lazy in removing parts of it. One of my first jobs will be to clean up the left overs.
Old 06-02-2013, 05:22 PM   #5
Old School
Willie T's Avatar
Sorry...... Couldn't resist.
Willie T
Old 06-02-2013, 05:24 PM   #6
That is some old Timber. If I had to date it, I would have to say late 19th Century, old Farm house. What part of KC are we talking? A lot was old farm land before build up, especially places like "Dog Patch", Lee's Summit, Independence.
Old 06-02-2013, 05:59 PM   #7
Rewards Points: 13,690
Also need to get rid of that improperly run and wrong material that was used in that dryer vent.
Old 06-02-2013, 06:13 PM   #8
Rewards Points: 39
The house is in the West Plaza area from 1915.
The dryer vent is obsolete as well as the washer and dryer have been relocated to the main floor.
Steel I BEAM size whatsupteach Building & Construction 11 04-16-2012 01:19 PM
What's a good product to repair chip in steel tub to prevent rust? amodoko Plumbing 4 12-26-2011 08:37 PM
Proper trunk/duct size? gjones HVAC 7 12-06-2011 07:18 PM
drilling through steel I beam DIYguy2000 Building & Construction 3 11-21-2011 08:39 AM
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 07:31 AM
