Old 03-15-2010, 01:57 PM   #1
What size screws for furring strips on rafters
I plan to use 3/4 furring strips screwed to my rafters. 1/2 drywall will be attached later to the rafters. What size screws should I use to fasten the furring strips to the rafters?
TomFl is offline   Reply With Quote
Old 03-15-2010, 08:59 PM   #2
It would compare to the load created by the drywall alone, so typically you would be looking at a minimum of 1 inch penetration, thus a 2 inch coarse drywall screw if you are using a 3/4 inch furring strip. Of course these screws might crack your furring strips, so predrill your holes. Also use construction adhesive.
Richmond is offline   Reply With Quote
Dumb question... what size screws for mounting a panel? tigereye Electrical 3 03-01-2010 01:46 AM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
Underlayment for attic remode - size and screws Vermont1 Flooring 6 02-03-2009 09:43 PM
What type / size screws for subloor project... scheenstra Building & Construction 1 05-17-2008 09:22 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
