-   -   What size screws for furring strips on rafters (http://www.diychatroom.com/f19/what-size-screws-furring-strips-rafters-66843/)
TomFl 03-15-2010 12:57 PM
I plan to use 3/4 furring strips screwed to my rafters. 1/2 drywall will be attached later to the rafters. What size screws should I use to fasten the furring strips to the rafters?
Richmond 03-15-2010 07:59 PM
It would compare to the load created by the drywall alone, so typically you would be looking at a minimum of 1 inch penetration, thus a 2 inch coarse drywall screw if you are using a 3/4 inch furring strip. Of course these screws might crack your furring strips, so predrill your holes. Also use construction adhesive.
