What Size Header? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-02-2011, 08:31 AM   #1
What size header?
I am opening the wall between my kitchen and back room (originally a 3 season porch)
1) wall is 12' long to a corner, then 4' back to end of kitchen.
2) There was a slider in the wall that had a header consisting of 2 2x10's.
3) I would like to take out the corner and open the room up. Here are my questions:
A) Can this be done?
B) What size header would I need to support the 12' and 4' spans?
C) Can I tye the header into the joists and remove the corner, or do the headers have to be supported down to the floor?
Thank you for your help.
DIYMom23 is offline   Reply With Quote
Old 04-02-2011, 09:21 AM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,286
Question C is a bit disturbing, you should learn more about structure before you dive into this project.
With that said, many local lumberyards will spec the beam for you. Engineering questions are typically not answered here because it's all about what it's supporting and removing 12' is a fairly large load.
Do you have a before and after floor plan mapped out that you could post?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 04-02-2011, 09:42 AM   #3
Framing Contractor
With a question like that, you HAVE to higher a professional and file for permits and inspections.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 04-02-2011, 10:57 AM   #4
Carpenter
dtsman's Avatar
Doubled up 2x10s lead me to believe this a load bearing wall and the description you give leads me to believe it use to be an exterior wall. Based on that guess, there is no way to get rid of that corner. 12' of unspported house at an outside corner just isn't going to work.
Maybe post some pics if I am not understanding.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
what size header should i use? jakejr13 Remodeling 1 07-25-2010 06:46 PM
framing and header size for garden shed jcall100 Building & Construction 1 07-11-2010 08:29 PM
Cripple studs below a header mercy Building & Construction 3 01-20-2010 04:20 PM
sliding patio door header... sharp Remodeling 2 11-03-2009 04:50 PM
Top plate over header? zenman Building & Construction 6 08-05-2009 01:04 PM
