What Size Gravel To Use Under Concrete Pad - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-06-2011, 05:45 PM   #1
What size gravel to use under concrete pad
Can I use 3/4" (crushed/angular) gravel under a concrete pad?
The pad is 5x5ft. I'll pour 6" concrete over 6" of ??. I'm using #3 rebar.
I have a lot of this gravel, and also unsorted sand, so I'm hoping one of those options are ok to use?
If this matters, the ground is very hard (Arizona) - has to be wet overnight to dig it.
woof24 is offline   Reply With Quote
Old 05-06-2011, 06:19 PM   #2
3/4 is what I used
fjacky is offline   Reply With Quote
Old 05-06-2011, 09:20 PM   #3
Rewards Points: 1,092
Woof: 3/4" or less, and compactable, if a house slab. What are you pouring 5' x 5' that requires 6" of concrete? Are you storing Abrams tanks?
Old 05-08-2011, 10:57 AM   #4
rain tanks
I am putting in rainwater catchment tanks: 4ft diam culvert x 10 ft tall. The culvert will be stood on end into the wet concrete.
Thank you both for your help.
Old 05-08-2011, 01:38 PM   #5
Approx numbers: 340 cubic feet. 21,760 lbs. 1813 pounds/sqr ft. I think you'd be safe w/ a steel reinforced 4" slab, and if you go to 6" with only one layer of steel, you may be wasting 2" of concrete. But, I'm not an engineer. Is the #3 bar 12" OC in both directions? Placed below center line of slab (approx 1/3 of the way up)?
Old 05-09-2011, 10:09 AM   #6
Yes to your questions on rebar and placement of it. Since posting I've chatted with an engineer friend who said 4" concrete is plenty. He also suggested 1" sand, then 4" of 3/4" gravel (compacted) then the 4" concrete. Am going to try that!
Thanks for your help ...
Tags
concrete , concrete base , gravel
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 12:03 PM
Plumbing line in exterior concrete for pool Hawk334 Plumbing 4 07-04-2009 10:13 PM
Gravel crawl space. Plastic vs concrete howard.wheaton Remodeling 1 10-19-2008 12:12 AM
concrete funnel for gravel? Moritz Building & Construction 5 04-13-2008 09:07 PM
