What Size Drill Bit For A 5/8" Bolt? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-31-2008, 10:26 PM   #1
What size drill bit for a 5/8" Bolt?
I am building a Pergola with 5/8" Lag bolts to support the posts to the beams, and I want to make sure that the drill bit I use is not too big. What size drill bit would you use to get a 5/8" Lag Bolt through?
Matty16 is offline   Reply With Quote
Old 07-31-2008, 11:00 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
7/16" to 1/2" for 5/8" lag screw, BOB
Old 07-31-2008, 11:07 PM   #3
Custom Cabinet Maker
Bob; the root diameter of any thread will be the proper size. Root diameter is the dimension of the bottom of the thread. You can Google " pilot hole for 5/8 lag bolt" and bet the exact size http://www.portlandbolt.com/technica...olt-chart.html Here is a chart for ya.
skymaster is offline   Reply With Quote
Old 07-31-2008, 11:23 PM   #4
buletbob's Avatar
Correct skymaster Thanks for the chart. 13/32" is what they state for 5/8" lags which is 1/32" shy of 7/16" I don't think that will make that much of a difference, being that a 7/16" spade bit would be more common for a home owner or DIY'er Thanks again.
Old 08-01-2008, 07:32 AM   #5
you guys're makin' what little hair i have left hurt just pick a bit that's the size of the bolt's center EXCLUDING thread height,,, threads're for pullout strength & the center's for shear,,, scheeeesch, next thing you know, i'll probably find a couple of you on the ibmwr site
yesitsconcrete is offline   Reply With Quote
Old 08-01-2008, 09:05 AM   #6
Thank you!
Thank you guys, I will use your advice. Much appreciated! I may be on here this weekend, bleeding & injured, and asking more questions as the Pergola is going up.
Old 09-04-2008, 12:15 PM   #7
PaulC - San Diego
ibmwr...
Originally Posted by yesitsconcrete View Post
....next thing you know, i'll probably find a couple of you on the ibmwr site
I'm on the ibmwr site and I just had to sign up when I saw the comment. Very appropriate or should I say very fitting? I was wondering what size to drill and I knew there was a standard so I went searching in google.
My bmw is a 1992 k75s and I bought it 6 years ago. What do you ride?
mrbios is offline   Reply With Quote
Old 09-04-2008, 01:51 PM   #8
76 r 90/6, 82 r100rs, & fyk 85 r100rs,,, can't being myself to spend the $$$ for newer models,,, 75s is a great bike - c bars ?
apologies to the rest of the board/thread
Old 09-05-2008, 11:36 AM   #9
PaulC - San Diego
The C bars wern't big enough, I converted to the bars from RT, and I ponder going to even bigger custom bars that come back further.
I don't see many air heads in san diego, is it tought to keep them up? Are most parts available? I have done tons of work to my k75s but it runs like a top even with 62K on it.
My apologies to the rest of the board/thread as well.
Old 01-13-2014, 10:53 PM   #10
i have a sofa i need to drill holes in the frame to screw in legs the threaded bolt on the legs is 5/16 i also purchases tee nuts that are 5/16-18x3/8 that were recommended from leg manufacturer. i would like to know what size drill bit i need to use for this. i would appreciate any help you can give thank u mary jane
maryj335 is offline   Reply With Quote
Old 01-14-2014, 10:24 AM   #11
Rewards Points: 4,534
i'd use 1/4"
Old 01-14-2014, 11:47 AM   #12
Rewards Points: 690
If you want the two members to pull together tight you'll bore two sizes of holes concentric. The first hole ( anchor hole ) will be the root diameter of the screw through the first member and into the second member the required distance. The second boring should be the major diameter of the screw completely through the first member. This will allow the screw head and washer to pull the two members together tight. Where you'll really see the difference is with twisted warped lumber.
Sometimes good things take a little longer.
Old 01-14-2014, 01:46 PM   #13
47_47's Avatar
Rewards Points: 44
The hole for a 5/16" t-nut should be 3/8". The length of your t-nut is 3/8", so, I'd drill it 1/2" deep.
47_47 is offline   Reply With Quote
Reattaching baseboards? Joony Flooring 7 07-06-2008 09:11 AM
recommendations for an all-purpose drill mcvane Tools 18 11-29-2007 10:12 AM
what size drill bit? econdave General DIY Discussions 3 10-11-2007 06:23 AM
Drill to mix thinset dbrew Tools 25 08-08-2007 11:48 AM
