What Size Dehumidifier Do I Need? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-07-2012, 02:05 PM   #1
What size dehumidifier do I need?
I've got some moisture in the basement and am looking at dehumidifiers. However, I can't find any consistent guidelines as to what size to get. Some sites I've checked indicate I would be fine with a small 30 pint, others have indicated that I need to spring for a 70 pint or larger.
My basement is about 820 square feet. The previous owner had problems with basement moisture, as she had a B-Dry perimeter drain system installed. We don't get pooling water (at least, we haven't yet in 9 months), but the hygrometer down there usually is between 60 and 80 percent humidity during the summer months.
Anyone have any size guidelines, or even brand recommendations?
Thank you so much!
thinksincode is offline   Reply With Quote
wire size for 1575 inverter 15' from battery bluemoonshine Electrical 8 12-28-2011 09:49 AM
Proper trunk/duct size? gjones HVAC 7 12-06-2011 07:18 PM
Rule of Thumb for Trowel size and Spacer size please.. K.M.G Flooring 7 02-08-2010 08:13 PM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 05:00 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
