What Size Ceiling Joist Do I Need? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-13-2013, 06:53 PM   #1
What size ceiling joist do I need?
I have a room with a span of 15' I want to have storage in the attic what is the minimun size ceiling joist I can get by with that will pass state code for nc?
gab465@yahoo.co is offline   Reply With Quote
Old 03-13-2013, 08:19 PM   #2
Civil Engineer
Rewards Points: 4,700
Simplest would be to go in and have a chat with your local building inspector. They will know exactly what building code applies.
Daniel Holzman is online now   Reply With Quote
Old 03-13-2013, 08:21 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
this is the 2012 North Carolina Residential Building Code. Select the species and grade of lumber you plan to use and the live load for your attic and check out the span tables.
http://ecodes.biz/ecodes_support/fre...C_Res_2012.pdf this will provide you with the size ceiling joist you need.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-13-2013, 08:40 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
15` span., id say atleast a 2x10 if not 2x12
woodworkbykirk is offline   Reply With Quote
Old 03-13-2013, 09:15 PM   #5
Roofmaster
Rewards Points: 2,172
Depends on what you are going to store up there. I would not go under 2 x 8's 16 OC regardless of what that code says.
Strengthen Ceiling Joist cocxanh Building & Construction 14 11-07-2012 01:27 PM
Bridging a ceiling Joist dR3w Building & Construction 1 01-05-2011 03:36 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
ceiling joist size for 10.6 foot width room hammeredmythumb Building & Construction 4 08-28-2009 01:54 PM
