What Size Beam Do I Need To Change To? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 04:34 PM   #1
what size beam do i need to change to?
I have a patio attached to my house and I want to change the 4x4 post to hollow tile and want to span the hollow tile columns every 20 feet. What size beam will I have to change the existing 4x8's to?
turtlekid is offline   Reply With Quote
Old 01-23-2011, 06:50 PM   #2
Rewards Points: 5,332
What are, "hollow tile columns"?
Ron
Old 01-23-2011, 07:56 PM   #3
I too am curious about the hollow tile columns. 4"x12" works for a garage door so at 20' span a 4"x16" should do the trick depending on the tributary load of the roof. You can go smaller with an engineered beam like a paralam.
Tigerloose is offline   Reply With Quote
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 12:08 PM
return vent size change philip18 HVAC 7 10-24-2009 11:18 PM
recessing a beam needa Building & Construction 12 12-26-2008 10:29 AM
Beam Size sevver Carpentry 15 04-30-2008 12:51 PM
Beam Load Ron Building & Construction 5 09-17-2006 06:28 AM
