What Should Be The Labor For Constructing A Dry Wall With Concrete Blocks ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-28-2011, 08:49 PM   #1
Cool
What should be the labor for constructing a dry wall with concrete blocks ?
How much I should pay for labor (all material is mine0 to a contractor for the following:
1.Concrete Block wall : Height 16 inch (2 blocks) by Length 130 feet
2. Stucco on one side .
3. Cement cap on top which is available at home depot for 1.50 per cap.
The contractor wants a labor of $8000.00 which seems high to me as the wall is straight 80 feet and then straight again 40 feet. Only 12 feet where it will curve a litle bit.
He will move some sprinklers and shrubs during his work as well well as few garden lights.
malhotrarm is offline   Reply With Quote
Old 02-28-2011, 09:05 PM   #2
Old School
Willie T's Avatar
Not a dime. Aren't you a DIY person?
Willie T
Old 02-28-2011, 09:38 PM   #3
I just joined today and do not know the benefits of being DIY member.
Anyway, can u help in giving an answer of my question
Old 02-28-2011, 09:49 PM   #4
concretemasonry's Avatar
Rewards Points: 2,594
Is this a retaining wall or just a free standing wall?
Once you insist of a stucco face, you are faced with concrete footings (may be required wherever you are hiding). This also means some sort of reinforcement (joint reinforcement or rebar). - the same applies to a poured concrete wall.
If it is a retaining wall, you can use segmental retaining wall block that are dry stacked with no footing (not allowed) or mortar, but the wall will have a slight batter toward the soil, but the block are usually colored and have a split architectural face. - In this case, the labor is very much less. They can be used for either inside or outside curved corners.
Dick
concretemasonry is offline   Reply With Quote
Old 02-28-2011, 11:19 PM   #5
Registered User
Rewards Points: 5,492
Welcome to the forum!
We can help you do it yourself but do not give prices here. They vary so much per location, etc....
Gary
Old 03-01-2011, 07:49 PM   #6
Dick,
Thanks for your response. This is just a wall 6 feet away from my fence in the back of my house. I just want to have concrete block wall with concrete capping (red color available at home depot) and stucco one side (Side which is showing)
Once again my plan is to have 16 inches in height and approx 120-130 feet in length. Nothing complicated?
Old 03-01-2011, 08:10 PM   #7
If your criteria is fixed with a stucco coating on a block wall you will have a wall that requires a footing and reinforcement to prevent cracks in the stucco wall. - simple, but a lot of work, excavation and concrete and is usually not a DIY job unless you have time and energy.
Insulating above grade concrete wall jhedger69 Building & Construction 6 07-23-2010 08:06 AM
Retaining wall concrete base -- how thick? RDS Landscaping & Lawn Care 1 04-23-2010 01:10 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
fiberglass insulation against concrete wall mike4 Building & Construction 4 03-27-2009 10:48 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
