What Is The Proper Way To Handle A Split Jamb Prehung On A 2x3 Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-12-2009, 09:51 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
What is the proper way to handle a split Jamb prehung on a 2x3 wall?
I just finished installing a prehung door on my 2x3 wall. I put the door side in like normal, then I cut 1/2" off the insert part of the split jamb all around with a jig saw and it slid right in. I know some people using some kind of furring for the casing like a 1/2 strip of molding or something. I like the fact that the way I did leaves the door looking normal. What is the "proper" way to handle this?
J187 is offline   Reply With Quote
Old 09-15-2009, 10:07 AM   #2
J187's Avatar
Rewards Points: 516
Bump for some feedback
Old 09-15-2009, 06:10 PM   #3
Rewards Points: 348
Unless you would custom order the doors I don't know of a better way than what you did.
Rege
RegeSullivan is offline   Reply With Quote
Best way to handle this - furring out concrete freeze wall J187 Building & Construction 10 05-14-2007 05:17 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
