What Is The Proper Type Of Caulk To Use Outside? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-17-2011, 08:17 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 70
What is the proper type of caulk to use outside?
I just used No More Nails for a hose bib install on brick but then I started thinking, that probably won't last the winter. I still need to screw it in better as I don't have tapcons so I'll be heading to the store tomorrow. What should I use to seal it so water can't get into the house? I cemented it in but I'm sure just that alone is not enough.
Old 05-17-2011, 09:45 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Try some 30 Year Window and Door caulk.
XXX
Old 05-17-2011, 10:35 PM   #3
Rewards Points: 5,336
100% silicone caulk behind the flange.
You don't need tapcons. A plastic anchor and exterior screws will work fine.
Ron
Old 05-18-2011, 09:16 PM   #4
Wire Chewer
Rewards Points: 70
Found the 35 year caulk today at CT.
though I am quite amazed at how good of a job No More Nails did. You'd think the valve was already screwed in and all, I could not even move it. I still screwed it in and also caulked around to cover the NMN as it did crack a bit and is probably not made for outside to begin with.
I'll monitor it over the summer but think it will hold up quite well. I put NMN on the indoor side too, I just shoved it all in the hole all around. It aint moving.
Old 05-18-2011, 10:16 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
ureathane based caulk/sealants work great on masonary,probably what the ''no more nails'' is based on
Tom Struble is offline   Reply With Quote
Circuit breaker Type Q vs QP orange Electrical 6 12-15-2010 04:35 PM
How to Clean Up Caulk Mess on Driveway Left By Construction Crew ToolbeltGal Building & Construction 6 09-25-2010 05:36 PM
caulk failed boston_michael Kitchen & Bath Remodeling 5 11-21-2008 06:30 AM
caulk question scatterbrain General DIY Discussions 5 10-04-2008 07:57 PM
Caulk Frustration j4ino Building & Construction 5 09-29-2008 08:03 AM
