What Perm For Interior Paint ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-26-2011, 05:47 PM   #1
Rewards Points: 199
What perm for interior paint ?
I lived in a mixed-humid climate (Western Arkansas).
My wall, from outside to inside, consists of vinyl siding/Zip wall sheathing/5.5" unfaced Roxul batts/5/8" drywall.
I'm wondering if I should use a low perm (<1 perm) latex primer on the drywall or if I should use typical latex primer (>5 perm).
The OSB in the Zip panels has a perm of 2-3, the membrane 12-16.
So, with a outer wall perm rating of 2-3 (which should allow drying somewhat to the outside), should I go with the low perm primer or the regular primer ?
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 12-26-2011, 05:50 PM   #2
Rewards Points: 13,458
Your way over thinking this, any quaility primer will work fine.
Old 12-26-2011, 09:38 PM   #3
Rewards Points: 1,092
sorry, but i don't agree w/ joe. inside should generally be 5x (as a goal) more permeable than outside, though in ark that may not be accurate. i'd use the lesser perm rating, and make sure you have air sealed real well; that is more important than the paint. you may want to dig into buildingscience.com, and if they say i am telling a tale, pls advise.
Pern value of 8 inches of open cell foam millertimeny Building & Construction 0 03-23-2010 11:28 AM
rigid foam insulation ctkeebler Building & Construction 24 11-09-2009 06:49 PM
