What Nails For Framing Walls? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By jklingel
  • 1 Post By renue74
Old 11-17-2016, 03:48 PM   #1
Rewards Points: 16
What nails for framing walls?
Need to frame some walls in the basement with 2x4s and wondering what size nails I should get? Length and diameter? I bought a paslode cordless framer to use. But when I went to home depot to get a box there were a lot of choices and just want to make sure I get the right ones since a box isn't too cheap.
ponch37300 is offline   Reply With Quote
Old 11-17-2016, 04:08 PM   #2
Rewards Points: 504
Re: What nails for framing walls?
My first question would be whether you have contacted the local AHJ? For instance, some will allow clipped head nails and some will not so, if your gun shoots clipped head, that's definitely something you need to know.
stick\shift is offline   Reply With Quote
Old 11-17-2016, 04:16 PM   #3
Rewards Points: 232
For that application I would use 12p gun nails. Be SURE that the box says for paslode....because you are entering world of paslode = paper collated, hitachi and porter cable = plastic collated and bostich = wire collated (listing only the guns that I am currently using!). Ron
ront02769 is offline   Reply With Quote
Old 11-17-2016, 08:17 PM   #4
jlhaslip's Avatar
Rewards Points: 980
Seems to me that Paslode uses a 30 degree angle, paper collated nail strip.
Being Canadian, I would use a 3 1/4 inch nail. Clipped head is fine.
I do not know what the American equivalent would be, ie: 16p or 12p, etc.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 11-17-2016, 10:20 PM   #5
Rewards Points: 161
Just an FYI, nails are sized in Penny the letter is a "d" not a "p". So a 3.24 nail would usually be a 12d nail not a 12p. The "d" is from something British.
paul100 is offline   Reply With Quote
The Following User Says Thank You to paul100 For This Useful Post:
jlhaslip (11-17-2016)
Old 11-18-2016, 04:04 AM   #6
Rewards Points: 1,092
The d is for the British penny, which used to be designated w/ a "d" from the Roman coin denarius, or some such. For smaller nails, each d increase meant a 1/4" increase in length, but that falls apart after about 12 or 16d. Either way, 2-by wood means 16d nails to me, and common, cement coated. Just my feeling on it.
bob22 likes this.
Old 11-18-2016, 09:21 AM   #7
Rewards Points: 13,296
If you have a pressure treated bottom plate you'll need to be using ACQ approved nails.
They also can be used anyplace else, but must be used when in contact with pressure treated wood.
I also buy the ring shanked nails for more holding power.
Old 11-18-2016, 09:30 AM   #8
Rewards Points: 24
In my area, 16d (3 1/2") nails are used for framing. (Full round head, smooth). Works great for toenailing, etc.
chrisb75 likes this.
renue74 is offline   Reply With Quote
Walls bowing out in large room hoffmandirt Building & Construction 8 07-14-2015 08:01 AM
What type of nails we should use for sheathing roof and walls of a shed? vikasintl Building & Construction 21 05-18-2012 10:52 PM
Used the wrong nails. ndmeier Remodeling 10 02-18-2012 11:42 PM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 05:12 PM
