Old 09-22-2009, 12:00 AM   #1
what is the method to cut my concrete patio slab
my patio slab has too many curves, i want to cut the slab making it a straight line. also, is it wise to do this or should i just remove the whole thing. it's about 10'x15' approx. 4" thick. can anyone give me some advice. thanks.
dragonfeeder23 is offline   Reply With Quote
Old 09-22-2009, 01:14 AM   #2
Moderator
Termite's Avatar
You can rent a walk-behind concrete saw at a tool rental center.
Old 09-22-2009, 07:04 AM   #3
we'd probably snap lines & hit it w/a demo saw altho my back may be younger than yours,,, at least i wouldn't have to worry about any annulus on THAT job
itsreallyconc is offline   Reply With Quote
Old 09-22-2009, 12:31 PM   #4
Concrete & Masonry
You want to rent something like this, at the very least.
CAUTION: These can be very dangerous to operate, make sure you read the safety manual first.
jomama45 is offline   Reply With Quote
Old 09-22-2009, 01:17 PM   #5
WaldenL's Avatar
Something to keep in mind too... You've got to get rid of that concrete. We hadn't considered that when we ripped up some concrete on the side of our house. Just having it hauled away cost us like $500. Add in the rental of the jackhammer and the time it took me to hammer it out, we should have just had it all done by a sub... Live and learn.
WaldenL is offline   Reply With Quote
Old 09-22-2009, 03:56 PM   #6
Moderator
And it may have rebar inside, unless you poured it... and can remember... To expose the rebar to water is not recommended.
I've never seen a saw that clean, only in the movies.
Be safe, Gary
Gary in WA is online now   Reply With Quote
Old 09-22-2009, 04:25 PM   #7
Concrete & Masonry
Be safe, Gary
I have, but only until we started it........................
Old 09-22-2009, 07:02 PM   #8
using the walk behind machine or the circ saw, do i need to make any relief cuts prior to going to work? thanks
Old 09-22-2009, 07:57 PM   #9
any relief cuts neccessary prior to?
Old 09-22-2009, 08:07 PM   #10
Concrete & Masonry
I,m not quite sure if I understand the question. Are you talking about control joints because this is a brand new patio, or due you mean "relief cuts" to remove the additional sections you don't want. If the latter, no, as a saw this size will cut deep enough to cut through the entire slab thickness. A circle saw will only cut 1/2 way through, at very best.
Flagstone patio - concrete slab or no? txpatioslab Building & Construction 5 04-14-2010 11:41 AM
building porch over concrete slab patio lachase Building & Construction 1 05-03-2009 02:43 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
flooring over concrete slab (enclosed patio) 1655graff Flooring 3 03-17-2008 07:22 AM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
