What Material Should I Use For Stair Risers/treads? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 02:01 PM   #1
Rewards Points: 508
What material should I use for stair risers/treads?
After finding out that prefinished acacia stair treads to match the upstairs flooring will cost me over $60 a piece, I'm pretty sure I want to carpet the stairs to the basement. I imagine I'll need to buy some sort of material with an eased edge to avoid wearing out the carpet. What should I use? 5/4 red oak? 2x12 SPF? Should I use the same material for the risers? I'm building the 36" stair with brackets (EZ-stairs).
benjamincall is offline   Reply With Quote
Old 01-24-2011, 02:29 PM   #2
Mabc's Avatar
If you're going to be covering the stairs with carpet you could use anything, I wouldn't use red oak though, extra cost for nothing, just use pine.
For the risers I'd suggest cutting them out of 3/4" plywood.
As for the stair treads, you could make them yourself with a 2x12 and a router for the edge.
Mabc is offline   Reply With Quote
Old 10-11-2012, 12:41 AM   #3
i am looking for a tread to match the asian walnut acacia flooring I am buying. Any clue where you found these for $60? I am looking for them to be 42" long with a left return and am also looking for a 52" starter stair with a left radius.
shuda is offline   Reply With Quote
Old 10-11-2012, 08:47 AM   #4
Rewards Points: 13,296
If you have never built and installed rizers and treads before I strongly suggest you think about hiring this one out.
There's a ton of codes that have to be followed, done wrong your going to have unsafe noncode compliant set of steps that may have to all be redone at some point.
If you go up to the top right where it says Search and type in stairs you'll see lots of DIY attemps on building there own steps that are going to have to be torn out.
And the other poster suggestion to just use 3/4 plywood is just not correct.
That would be 1/2 the thickness required for a stringer.
A 2 X 12 or an LVL would be far better.
Old 10-11-2012, 01:49 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 194
Fellows, this is an old thread.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Water Fall - Black bonding material cprao Landscaping & Lawn Care 3 04-23-2011 04:06 PM
framing material estimate maydoug Building & Construction 38 06-12-2009 02:32 PM
Ceiling Ventilation Fan rjordan392 HVAC 1 05-20-2009 06:41 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
