What Makes High Strength Concrete? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-18-2009, 02:36 PM   #1
What makes high strength concrete?
Quikrete sell concrete mix at 4000psi and 5000psi, what is the difference? Can you just add additional cement to 4000psi concrete mix to make it stronger? And what about hydrated lime, would adding some to the mix make it stronger? Thanks - just curious about what makes concrete stronger, I understand proper curing is very important.
jrepp is offline   Reply With Quote
Old 06-18-2009, 04:04 PM   #2
Civil Engineer
Rewards Points: 4,522
The strength of concrete is determined by a variety of factors. Probably the most important is the water to cement ratio. In general, the strongest concrete is formed by using the minimum amount of water necessary to hydrate the cement. Unfortunately, low water cement ratio concrete is quite stiff, and hard to work, so generally requires additives to make the concrete more plastic and easier to place and finish.
You cannot arbitrarily make concrete stronger by adding lime or more cement, since the strength is more a function of using the minimum amount of water in the mix. There are some admixtures that intrinsically add strength to concrete, however the most common reason for using an admixture is to allow lower water/cement ratio in the concrete, increasing the strength.
Old 06-18-2009, 04:09 PM   #3
Custom Cabinet Maker
Spinach
skymaster is offline   Reply With Quote
Old 06-18-2009, 06:41 PM   #4
concretemasonry's Avatar
Rewards Points: 2,570
Adding cement requires more water, which will give more shrinkage. If you are doing a little patch job, no one will know the difference, since it will always shrink and pull away from the old concrete.
If you really want high strength you start withe right aggregate gradations and plasticizers that will give workability, low water and high strength.
Since are dealing with minimum type of product to start with, you only can add cement and try ways to keep the extra water down. - In other words, you do not pour it, you "place" it and then finish it.
Dick
concretemasonry is offline   Reply With Quote
Old 12-20-2010, 10:47 PM   #5
Unhappy
what the factor effect the high strength concrete
hey everyone..
I have a problem with my design mix of high strength concrete that I have make.. actually I have do so many trial mix for get the high strength concrete and about 3 months I already spend.. but the result is so bad.. I dont know how my design cant achieve the 80Mpa for 28 days.. so bad when I test my cube for 7 day, the result is about 60Mpa++ but after 28 days I get so bad result which 15Mpa++.. i dont know why this happen.. i wanna to cry because i dont have so many time to do it again..
i am really need the help.. everyone who can help me please email me: putri_fiza87@yahoo.com..
Alia is offline   Reply With Quote
Old 12-20-2010, 11:22 PM   #6
Concrete & Masonry
Rewards Points: 470
Originally Posted by Alia View Post
hey everyone..
The problem you're having is simple, 12,000 psi concrete is nearly impossible to attain...................
jomama45 is offline   Reply With Quote
Laid Down Concrete Incorrectly overzealous Building & Construction 6 06-03-2008 07:44 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 09:58 PM
