What Length Staple Should I Use For Underlayment? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-26-2011, 04:29 PM   #1
what length staple should I use for underlayment?
Tomorrow I am renting a stapler that takes up to 1 1/2 inch narrow crown staplers. I am not sure what length staples to purchase.
I am stapling 5/8 inch plywood down onto plank flooring (subfloor) that is 3/4 inch thick. This comes to be 1 3/8 inch thick. I have never used a stapler before and not sure about the "rules." No one around here seems to know.
Can I use 1 1/4 inch staples? If I do, they will not go through all the way to the basement. If I use 1 1/2, they will show in the basement. I hope staples are not supposed to be 1.5 times the thickness you are going through like nails.
howdihi is offline   Reply With Quote
Old 08-26-2011, 06:57 PM   #2
Rewards Points: 5,336
I'd use screws, not staples.
Ron
B. Franklin 1759
Old 08-26-2011, 07:25 PM   #3
The code in Utah where I am allows for 1" 3/4 staples to be used to secure the floor sheathing. This is not allowed in all areas. Most people will tell you to use an 8 penny ring shank nail and alot of glue
Ninjaframer is offline   Reply With Quote
Old 08-26-2011, 07:43 PM   #4
Screw the code and screw the floor(with adhesive)
No squeeks
Ron
B. Franklin 1759
Old 08-26-2011, 07:47 PM   #5
The staples actualy seem to work pretty well as far as eliminating squeaks goes. If someone is worried about it I screw the hallways down in addition to the staples.
Old 08-26-2011, 07:49 PM   #6
If I did, and I have started doing that, how many per sheet of plywood. I have found that it has been a pita.
Old 08-26-2011, 07:52 PM   #7
So, I should be using longer staples than the underlayment and subfloor combined? I would be afraid I would hit some pipes downstairs. And the rental only goes up to 1.5 inches
Old 08-26-2011, 07:53 PM   #8
Im not sure what the UBC says but I would think 6" on edges and 8" in the field would be ok
Old 08-26-2011, 07:55 PM   #9
What about the floor joists? Can't you staple over them?
Old 08-26-2011, 07:58 PM   #10
Can I get away with using the length staples I proposed above? There are some squeaks with the subfloor. It is tongue and groove wood plank. How do I get rid of those squeaks?
So, when everyone is talking about getting rid of squeaks, is it the subfloor that is causing the squeaks usually so you nail down the underlayment a lot and it stops the subfloor from squeaking?
Old 08-26-2011, 08:00 PM   #11
Every 8"on the edge, 12" in the field.
There are screw guns that use 50 screw bandoliers that will make it go faster.
Ron
B. Franklin 1759
Old 08-26-2011, 08:02 PM   #12
I doubt you will be able to eliminate the squeaks in the planking completely. I'm guessing it's nailed down with smooth shank nails and unless you go through and tighten it up first I think your going to find that it still squeaks no matter how you install the new sheathing.
Old 08-27-2011, 05:27 AM   #13
kwikfishron's Avatar
Rewards Points: 1,024
Now there’s a brilliant thought.
kwikfishron is online now   Reply With Quote
Old 08-27-2011, 10:59 AM   #14
Registered User
Rewards Points: 526
Be sure to orient the plywood properly if no t&g edges: http://www.apawood.org/pablog/index....-Floor-Systems
Acclimate it, leave end gaps, step #2; refasten sub-floor, as said- step #3; no glue for certain sheet goods, step #4; Table #2 for fastener length, offset all joints. http://www.apa-europe.org/Languages/.../PDF/R340G.pdf
Gary
Staple up, warmboard or gypsum concrete? jelly HVAC 6 08-16-2011 11:35 PM
Staple length for Carpeting Staircase Nick DIY Flooring 2 01-20-2011 01:33 PM
Hardwood Length...preference? JDeFuria Flooring 3 03-10-2009 05:38 PM
Staple Length Bpawb Flooring 1 05-06-2008 03:28 PM
wire staple removal madmax55555 Electrical 8 07-03-2006 05:29 PM
