What Kind Of Tool Do I Need For This? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-27-2009, 02:51 PM   #1
What kind of tool do i need for this?
hi, names mike.
i have a security gate on my front porch i would like to get rid of but i need some info. its bolted into the ground, ceiling and side walls with a particular bolt i'm not familiar with. Can i get a bit for this from a home improvement store? what is this called?
thanks
inkjet is offline   Reply With Quote
Old 03-27-2009, 02:58 PM   #2
Grind the head off.
Looks like a torx.
redline is offline   Reply With Quote
Old 03-27-2009, 03:02 PM   #3
Rewards Points: 562
You would need a hollow head torqs,,never saw one like that before. Has to have a hollow bore like a nut driver,,,sorta with outer torqs drive. Unless that center piece pops out somehow. or is this a rivet type fastener. grinding prolly quicker.
4just1don is offline   Reply With Quote
Old 03-27-2009, 03:11 PM   #4
It's a tamper proof torx screw and it will be hard to find a socket head for it. Grind it or sawz-all it off.
Jim Hart is offline   Reply With Quote
Old 03-27-2009, 03:11 PM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
That looks like a T-27 Button Torx ® w/pin. You are not likely to find a socket at the Big Box. If not first try a cold chisel & Hammer
http://www.hudsonfasteners.com/sec/sec_tx_bhpsts.htm
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-27-2009, 03:15 PM   #6
Old School
Willie T's Avatar
Looks like a Uni Star Head. Try this
http://store.solar-electric.com/43661.html
It also resembles a Scott's Stabilizer Security Bolt. But I don't have their address.
Willie T
Old 03-27-2009, 03:19 PM   #7
Concrete & Masonry
Rewards Points: 568
I found a bit for that at my local True Value a few years ago. It's a bigger store with a great inventory, so I dont think most hardware stores will have it. Def not at a big box.
jomama45 is offline   Reply With Quote
Old 03-27-2009, 03:52 PM   #8
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
I have used a dremel and ground off the nob in the center. Use appropriate size torx after that.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 03-27-2009, 05:13 PM   #9
thanks for the quick replies. yeah i figured it was some kind of tamper proof thing. reminds me of some of the ones i've seen in public restrooms to hold stalls together. i decided to just grind them off, some of them look pretty rusted so i would probable end up needing the grinder anyways.
thanks again!
Mike
Old 03-31-2009, 05:48 PM   #10
Yes, this is a tamper proof torx head. I have one in my tool box.
These are used in some automotive applications also.
If can find a auto tool dealer such as Snap-On, Mac, Matco any one of them should have your bit to remove this.
--also depending on the quality of the fastener you might have luck breaking off the center pin with a punch.
oregondiy is offline   Reply With Quote
Old 03-31-2009, 06:27 PM   #11
Love for Construction
<*(((><'s Avatar
harbor freight FTW.
<*(((>< is offline   Reply With Quote
Old 03-31-2009, 06:56 PM   #12
Man of many hats
wrangler's Avatar
Rewards Points: 354
I would run into them from time to time when having to take burglar bars off windows to replace them and found it just as quick and easy to pry the whole unit off with a flat bar/crow bar and hammer. If the surrounding brick/mortar/stucco was delicate then I would grind the head off to prevent damage.
Man of many hats
wrangler is offline   Reply With Quote
Old 03-31-2009, 07:06 PM   #13
Household Handyman
Rewards Points: 1,408
Take a small pin punch, use it to break out the center pin, they break out easily. The use the appropriate size Torx driver to remove the screw. Don't expect that screw to just back out though. Depending on what it is screwed into you may need to give it a good dose of some type of penetrating oil the day before. Good Luck. David
Old 03-31-2009, 11:20 PM   #14
Security Torx. Lowe's carries them. I saw them yesterday when I was there plus I bought a set from Lowe's a couple years ago.
KHouse75 is offline   Reply With Quote
Drywall Inside Corner Tool? helpless handyman Drywall & Plaster 24 02-19-2009 06:02 PM
Tool conglomerations, who owns who ? iMisspell Tools 19 01-27-2009 12:41 PM
the tool for mounting real short nipples amakarevic Plumbing 2 11-01-2008 12:34 AM
Tub Drain Removal Tool rjordan392 Plumbing 6 07-08-2008 11:39 AM
