What Kind Of Stone Under Concrete Slab? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-15-2011, 08:18 PM   #1
Do it right.
What kind of stone under concrete slab?
I am getting ready to have a foundation poured for a garage this summer, I am new to foundations so I asked my building inspector what kind of stone I needed under the slab and the only response he would give me was "You figure it out" It would have taken him less effort to list the stone, but thats for another day.
Anyways, help is appreciated, I have come across a dozen different reccomendations on the internet and I don't know which is best.
SubSailor is offline   Reply With Quote
Old 04-15-2011, 09:15 PM   #2
concretemasonry's Avatar
Rewards Points: 2,626
You do not want "stone", whatever that means in your area. Clean stone does not compact at all unless it is dirty or contaminated with finer materials.
You want a compacted base that is similar what is used under roads and driveways. He was correct in not giving you a specific material, but could have given you a specification to use when you buy or contract it.
Is it a "floating foundation" with thickened edges or is it a foundation of a stem wall on a strip footing with a true floating slab between the stem walls. Those are two distict types with plusses and minuses depending on what you climate and needs are.
You asked him a specific question for a material that is acceptable without any regard for how it performs or is installed. There is no one answer since you obviously do not have a real design/specification.
Dick
concretemasonry is offline   Reply With Quote
Old 04-15-2011, 09:51 PM   #3
Rewards Points: 1,016
I have built a couple threee workshops and garages - all being in southern and non-freeze areas I put down a monolithic slab - with packed in sand for a base on undisturbed ground after the grass or any other organic matter that would decompose was removed.
Old 04-16-2011, 07:13 AM   #4
Concrete & Masonry
Rewards Points: 620
What you want is what we would refer to here as gravel, a mix of gradients of aggregate, from 1" stones down to fine material such as non-washed sand. A few viable options depending on what's it's called in your area: "3/4" road gravel, recycled/ground concrete, 3/4" traffic bond, etc..."
jomama45 is offline   Reply With Quote
Old 04-16-2011, 09:25 AM   #5
Do it right.
Dick
I asked him a specific question with him knowing the specific type and size of foundation, location and drainage attributes. He chose not to answer it.
it's going to be a pier slab system, 6" thick slab poured together with 12" dia. footings about every 6 feet.
insulating exterior of concrete slab home.. rvegab00 General DIY Discussions 5 10-15-2009 09:26 PM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 02:17 PM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 05:14 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 12:32 AM
