What Kind Of Render - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-11-2007, 10:24 AM   #1
what kind of render
i want to render the inside of my fireplace before i have a wood burning stove fitted, what mix should i use.
nickydupps is offline   Reply With Quote
Old 02-11-2007, 10:40 AM   #2
Darylh's Avatar
render ??
Darylh is offline   Reply With Quote
Old 02-11-2007, 11:17 AM   #3
render-sand cement mortar used before plaster, i heard that because of heat from stove the render should have lime in it?
Old 02-11-2007, 09:53 PM   #4
Construction Guru
I've never heard it refered to as render Nickydupps. In my area, we call it parging. I have a little experience at repairing the inside of fireplaces. I've always used refractory mortar to point up the bricks and to parge the inside for traditional fireplaces. I wouldn't think that you would need to do it much if you are installing an insert wood stove. The steel casing should provide some protection unless your bricks are greatly deteriated. Many wood stove inserts these days have an inner and outer casings, with a blower circulating air inbetween.
sheeter is offline   Reply With Quote
Old 02-12-2007, 01:58 PM   #5
Rewards Points: 1,220
"Render" is English for "stucco", broadly. Sand/cement should be fine what you are doing; 1 part masonry cement to 3 parts sand.
Tscarborough is online now   Reply With Quote
Old 02-13-2007, 11:34 PM   #6
Darylh's Avatar
To a 3 to 1 mix I would throw in a 1/4 shovel of type 10 portland cement. I always found it makes a smoother and trowels nicer.
Old 02-14-2007, 01:15 AM   #7
thanks for all your help, i feel confident in doing the work this weekend. cheers
Old 11-03-2007, 08:04 AM   #8
We are just about to have a wood burning stove fitted and have a similar question really. We have a 1950's house so the bricks are grey and ugly now the brickwork has been exposed since taking out the fireplace. We would like it rendered but have been told it will crack so the guy fitting intends to coat over the brickwork. I was really hoping for a smooth finish...does anyone have any ideas?
smiler55 is offline   Reply With Quote
what kind of wire is this? fall4mui General DIY Discussions 8 08-07-2007 10:01 PM
What kind of flashing Malcolm Roofing/Siding 4 06-20-2007 02:59 PM
what kind of air nailer to get? johnny331 Remodeling 5 06-05-2007 09:33 PM
What Kind of Wiring? Chuckman Electrical 12 05-30-2006 10:04 PM
painting over drywall -- what kind of prep? CindyF Painting 6 01-12-2006 01:54 AM
