What Was I Thinking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 07:57 PM   #1
What was I thinking
Ok so I thought a deck would be nice to have on our lot. I decided a platform freestanding would be easy. How hard could it be? right? Well I framed a 2x612x16' start of a deck using deck blocks. I plan on supporting the deck with 20 deck blocks. I put in 4-16' beams spaced about 2.5' apart. this is the dilemma. I believed I spaced the beams too far apart. I was going to block the beams ( mind you thats the only construction lingo that i know) with spacers to sturdy the deck. My contractor say there is too much space between the beams which is potentially hazardous. So my question to you all is am I on the right path or do I need to start over? How many beams do I need for a 12 x16 deck? how far should they be spaced? Is there an alternative solution then to start over? This is a cry for help.
diydiva1 is offline   Reply With Quote
Old 06-25-2012, 08:01 PM   #2
Framing Contractor
Originally Posted by diydiva1
Ok so I thought a deck would be nice to have on our lot. I decided a platform freestanding would be easy. How hard could it be? right? Well I framed a 12x16 start of a deck using deck blocks. I plan on supporting the deck with 20 deck blocks. I put in 4-16' beams spaced about 2.5' apart. this is the dilemma. I believed I spaced the beams too far apart. I was going to block the beams ( mind you thats the only construction lingo that i know) with spacers to sturdy the deck. So my question to you all is am I on the right path or do I need to start over? How many beams do I need for a 12 x16 deck? how far should they be spaced? Is there an alternative solution then to start over? This is a cry for help.
Give your building department a call. Do you need permits and inspections where your from?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 06-25-2012, 08:21 PM   #3
Rewards Points: 13,250
Not even sure what your talking about.
By beams do you really mean joist? If you meant joist they should have been 16" on center.
And 2 X 6's will be under sized. There going to sag and bounce.
You really need to do far more research before doing any more work.
A simple deck building book from HD or Lowes may help.
Old 06-25-2012, 10:14 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
No offence, your deck building lingo is mixed up. a picture will possibly describe much more.. thanks
hand drive is offline   Reply With Quote
Old 06-25-2012, 10:55 PM   #5
robertcdf's Avatar
She's trying to use these deck blocks they're really kind of garbage in my opinion but they can be ok for a small NON attached deck. I wouldn't be caught dead using them as they are designed for the most basic of DIY.
robertcdf is offline   Reply With Quote
Building a shed...am I not thinking of something? Madison Building & Construction 5 03-19-2012 07:59 PM
thinking of installing Bathroom Heat lamp in basement Juliediy Electrical 3 04-06-2011 01:03 PM
Laser died - need suggestions for a replacement - thinking about Bosch... restorick Tools 0 04-07-2010 10:04 AM
Thinking of Buying house with Flat roof lpcon Roofing/Siding 3 08-19-2007 09:23 PM
thinking about tring to get my license weekendwork Electrical 1 09-26-2005 07:30 AM
