Old 04-13-2011, 12:49 PM   #1
what hardware cctv to aluminum soffit
Hi,
I'm looking for idea how best to attach a cctv camera below my aluminum soffit. Less than a pound.
Is there a corrosion reaction I need to keep in mind?
Do I use plain old zinc coated metal screws?
And then....do I use a molly? The access from the inside is kind of sketchy...so I pretty much will be drilling a hole from the outside.
A metal screw seems like it wouldn't have enough bite...I would think I would need some type of backing to it.
Any ideas?
D270 is offline   Reply With Quote
Old 04-13-2011, 04:27 PM   #2
There is interval blocking under the soffit material. If it's not where you need it, remove the aluminum material and install blocking.
You can isolate the 2 metals with a gasketing material and use stainless steel fasteners. Zinc is for the interior.
Ron
Old 04-13-2011, 07:28 PM   #3
Perhaps it would be easier to mount it on the wall, rather than the soffit. If its a brick wall you won't have any problem mounting it.
aluminum soffit repair question bergerdude Building & Construction 9 03-26-2011 04:01 PM
How to gently remove (aluminum) soffit? superfly Roofing 1 09-06-2009 10:15 PM
Help with installing aluminum soffit and fascia Boontucky Roofing 3 09-01-2009 08:47 PM
Soffit Venting for Aluminum Sofits kevn83 Roofing 3 07-23-2008 09:05 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
