What Is A Good Way To Anchor/secure A Pergola To A Paver Patio? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-08-2009, 12:21 PM   #1
Ummmm...
Shpigford's Avatar
What is a good way to anchor/secure a pergola to a paver patio?
So I just laid a large-ish patio with pavers (with the joins filled with sand) and now we're wanting to build a 12'x12' pergola on the main area.
I know ideally I should have planned the pergola before hand and set the posts first or at least left a few of the pavers out, but alas foresight wasn't one of my strengths here.
So, the question now is how do we anchor the pergola to the patio? We don't want to anchor to the house...so it's just a freestanding, 4 post structure we're going for.
I've read about using steel rods drilled into the pavers/ground as a way to anchor, but wasn't sure if there were any better/easier ways of going about it.
Additional bits of info is that pavers are 3 inches thick plus 1" of sand and 4" of 3/4" crushed mountain granite below those pavers and then just good 'ole dirt below that.
So, any advice/tips on this would be great.
Shpigford is offline   Reply With Quote
Old 07-08-2009, 01:17 PM   #2
Registered User
Rewards Points: 5,204
Depends on location and high winds area. I wouldn't trust the stakes for up-lift. I would use something similar to this: http://www.strongtie.com/products/connectors/CBSQ.asp Pour a footing down at your frost level and use gravel under and as back-fill. http://books.google.com/books?id=1gg...num=3#PPA31,M1
How gravel prevents frost heave: http://www.sustland.umn.edu/implemen..._footings.html Be safe, G
Old 07-08-2009, 01:18 PM   #3
Ummmm...
Shpigford's Avatar
Thanks GBAR, I guess I'm really wondering if there's a way to anchor the thing without having to pull up pavers and pour concrete.
Old 07-08-2009, 02:02 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Nice Patio, I'm sure the Pergola will be magnificent. Before sinking big bucks in the Pergola I would consider sinking a DIY foundation.
http://www.google.com/search?hl=en&r...&aq=f&oq=&aqi=
A proper foundation is always important. In Denver you also have to consider
Tornadoes
http://www.examiner.com/x-219-Denver-Weather-Examiner~y2009m6d7-Tornadoes-strike-Denver-area-damage-mall-overturn-cars
I would consider Sonotubes as there are ways to conceal the base to make it appear that the Pergola posts are just growing out of the ground.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-08-2009, 11:05 PM   #5
Rewards Points: 5,336
You can't really put that size structure on a paver patio, too much weight. You need to remove the pavers under the pergola where you pour the sonotubes. The piers will carry the weight of the structure.
Ron
Old 07-12-2009, 02:12 PM   #6
morningwood
The pavers will not be any kind of support to attach the pergola posts to. I would do a proper footing.
It is much easier to pull up a few pavers now and do a proper footing and pave around it now then.....rebuilding your pergola after it falls down AND still having to redo some pavers becuase they pulled up with the post as the pergola fell over (hopefully not landing on anyone or anything).
Just me 2 cents...
rahfiki is offline   Reply With Quote
Old 06-13-2012, 11:49 PM   #7
what would happen if set on paver?
would the weight of the pergola make the pavers sag in that area?
I have about 20" of stone under my patio due to the grading that was there? does that make a difference?
JackLantern is offline   Reply With Quote
Old 06-14-2012, 12:02 AM   #8
AHH, SPANS!!!
Rewards Points: 1,166
up from the depths, maybe the original poster will respond..
hand drive is offline   Reply With Quote
Old 06-14-2012, 12:15 AM   #9
Tool Geek
PaliBob's Avatar
Yes this is a three year old thread. The poster should have started a new thread. The original comments were all good regarding weight and the importance of considering up-lift in wind.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-14-2012, 12:24 AM   #10
what is wrong with replying to an old thread?
Tags
pergola
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
PATIO PAL : Good or Bad? KUIPORNG Landscaping & Lawn Care 6 04-14-2008 04:24 PM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 11:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
