#1 |
what to get for bridging 2x6 24" oc?
Wanting to stiffen up my ceiling/2nd floor, but I can't find any steel bridging for 2x6 joists that are 2' OC. I went to
http://www.strongtie.com/products/CFS/TB-LTB.asp And they don't have anything listed for it. Is wood the only option? Bear in mind I don't want to rip up the 2nd floor to nail the bridging down, and I want drywall to go back up on these joists. |
#2 |
cut blocks of 2 x 6.
#3 |
I'd prefer the x bracing so it'd be easier to run wires and such. Are there no x braces made for a 2x6 24"oc?
#4 |
I would call your local lumber yard or where ever you buy your stuff from and ask them, I know you looked at Simpson but and I very easily maybe wrong here but I would have sworn in there Wood Framed Catalog in the Roof and Truss section that they had metal bracing for a 2 x 6 spaced 24'' o.c. like I said I maybe wrong and thus why i recommended calling your local dealer
I have not seen any other product out there outside of block of 2 x 6 |
#5 |
might need to cut your own from 2x material.
How do you plan on nailing it? that's why I suggested blocking. cut notches for the wires. or strap the bottoms helps, too. |
#6 |
Framing Contractor
That's because they don't make them the framers do. Cut 2x6 blocks and be done with it and drill a hole if you need to run a wire. How will you nail the bottom of bridging if you do decide to make it yourself without removing the ceiling?
Joe Carola |
#7 |
Oh well, I suppose if solid wood blocking would be best, then so be it. What's the best way to attach it? Just glue? I read that staggered blocking is not the best way, the that blocks need to be in a line from joist to joist, but I don't understand how they get attached to the joists unless they're toenailed.
I'm a noob, sorry ![]() And I never said I won't be tearing down the ceiling. I just don't want to tear the floor that's above the ceiling
#8 |
snap a line on the underside of the joists.
place the first block on one side of the line and nail the next block to the opposite side of the joist. this is called staggered blocking. that allows full end nailing to both blocks. where your space is limited, toe nail from the block side. glue would be good, well, it would not hurt anything. |
#9 |
Old School
http://www.strongtie.com/products/co...TB.asp#tables2
But only 2x6 with such a wide spacing may be impossible to find. Perhaps you could measure the length you'll need, and substitute something on the page in the link. You should be able to get by with something 25 to 26 inches long. But 27" might be too long. If you cannot find the ready-made metal braces, here it is in wood. (BTW, no need to stagger those solid blocks so far apart as they show here.) (HINT) For solid bridging..... Determine where you will need holes, (how many braces drilled) and drill them BEFORE you cut the brace piece off the length of lumber. MUCH, MUCH easier and faster than working off a ladder later.
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Willie T Last edited by Willie T; 01-25-2010 at 10:43 AM. |
#10 |
Moderator
Keep solid blocks in-line for strength, Number 6: http://www.finehomebuilding.com/PDF/Free/021184090.pdf
Cross bridging is stronger: http://books.google.com/books?id=DWs...olumns&f=false Use the right "stuff": http://books.google.com/books?id=8tN...idging&f=false Be safe, Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#11 | |
Framing Contractor
what to get for bridging 2x6 24" oc?Quote:
Joe Carola |
#12 | |
Old School
C'mon, how much can you bend a 2x12 in an inch and a half? And what about the cross bracing they are showing? The opposite ends of each piece on the other side of the joist are staggered by at least 2 full inches. That's a lot more offset than staggered blocks. Never have heard of a problem with staggered solid bridging in almost 50 years in the industry. Sure, it looks prettier to butt straight on, but for the extra hassle of installation, not worth it.
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Willie T |
#13 |
diagonal bridging if not secured before subfloor sheathing will eventually squeak imo
#14 |
Ok guys, thanks. If staggered is just as good as in-line, then great!! I'll get some Liquid Nails and glue/nail in place. I watched the joists deflect when I had another person jump on the ceiling. It's not a lot of deflection, but enough to cause the ceilng to crack, so I'm definitely going to bridge. I also need to relevel the first floor sometime and put a support under a floor joist that has no midspan support (the wall that's bearing the 2nd floor happens to be on top of the unsupported floor joist as well).
Is it alright to bridge the 2nd floor before I deal with the sagging first floor? |
#15 | |
| Display Modes | |
| 24" O.C. with tile? | jackie treehorn | Kitchen & Bath Remodeling | 9 | 01-01-2010 05:38 PM |
| tile saw advice for 24" porcelain tiles | diy'er on LI | Tiling, ceramics, marble | 12 | 10-11-2009 04:34 PM |
| Replacing wood on 24" center trusses | Novar | Roofing/Siding | 2 | 04-24-2009 08:24 PM |
| 24" conduit rule derrating does not apply | jamiedolan | Electrical | 10 | 02-27-2009 10:26 AM |
