Old 11-12-2007, 11:06 AM   #1
What fastener to secure 5/4 decking directly to concrete
I'm installing a deck directly over a preexisting concrete patio. The concrete patio has a step right in front of the back door that is exactly the height of a 2x8 (7.25 in) if said 2x8 is used as a floor joist. Therefore, most of the decking will be going on the 2x8's however a 3'x3' area corresponding to the preexisting concrete patio back door step will have decking material lay directly on top of it. I am considering using the following to secure the decking to the surface of the preexsiting concrete patio step:
1.) 2 1/2" Tapcon screws (spray paint heads tan to match deck mate screws),
2.) 2 1/2" tapcon screws with USP Connectors CIA-EA Epoxy Anchoring Adhesive in hole to help hold Tapcon screw,
3.) deckmate mate screws with plastic concrete anchors, or
4.) deckmate mate screws with plastic concrete anchors AND USP Connectors CIA-EA Epoxy Anchoring Adhesive (this I'm not sure can be done since the epoxy might be incompatible with the plastic anchors... perhaps someone could chime in on this).
I'm particularly worried about the durability of any fastener option I chose since these boards will be walked on everyday, thus creating a challenge for any fastener to keep from working loose. What I'm wondering are two things: Besides the options I have listed, are there any other options that I haven't considered that would hold up better. Take in mind that large hex bolt heads would be unsightly if used for this application (even if recessed and spray painted tan), thus the reason for the only two screw options listed above with wood screw heads. Otherwise, if no other options exist, of those options listed, which would think would hold up the best. I'm partial for option 4 since I'm worried about even just one Tapcon screw head shearing off (which I've had happen before) which would be a bear to deal with.
Thanks in advance!
howaboutthat is offline   Reply With Quote
Old 11-12-2007, 11:43 AM   #2
I'm going to be tackling a similar project next spring I think. I've got a raised concrete step above a concrete patio. The patio is 12 shades of uneven though, and having just bought the house I don't know how long it's taken for the patio to heave that much, or if it was just poured really poorly. I think I'm going to demo both the patio and the raised stoop and bury the supports the 48" they need to be for my area. Then I'll re-grade the new dirt to get proper drainage. My only concern will be locating the main sewer line coming from the basement, but that shouldn't be too hard to find.
perpetual98 is offline   Reply With Quote
Old 11-13-2007, 06:09 AM   #3
howaboutthat,
I'd lay some strips down first...... even 1/2 thick....something to keep the decking off the concrete directly....... as far as ataching them, any of them will work.
perpetual98,
Call the local UFPO aka Digsafe............. they'll locate all that stuff for you.
mdlbldrmatt135 is offline   Reply With Quote
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
