-   -   What fast setting adhesive to stick light to ceiling? (http://www.diychatroom.com/f19/what-fast-setting-adhesive-stick-light-ceiling-71498/)
minoan 05-18-2010 10:07 AM
In an array of 6 low voltage ceiling lights one has become so loose in its hole in trhe plasterboard ceiling that it will not stay in place with the usual spring arrangement. It hangs on its wiring at present.
Is there a very fast setting, and strong, adhesive which could be used to stick the light fitting in place in the ceiling? It would have to be very hard grabbing, and fast setting, so that the fitting could be pressed up against the ceiling, and would then stay in place. There is no way to hold the fitting up for a long time.
DangerMouse 05-18-2010 10:16 AM
Hi and welcome to the forum.
JB-QUIK made by JB Weld sets in 4 or 5 minutes and may do what you need.
There is 2 part 5 minute plain epoxy too.
This of course depends upon the ceiling surface.
Can you post us a picture? That always helps, and there may be an easier solution another may suggest!
DM
Branden 05-18-2010 11:29 AM
Would it be possible to cut a 2x4 to the length of your floor to the fixture that you need to hold in place? If so, you can use liquid nail and use the 2x4 to hold it against the ceiling for a day to dry. Seeing a pic would be helpful
minoan 05-18-2010 12:27 PM
1 Attachment(s)
DM
Thanks very much for this suggestion. The problem boils down to sticking the brass rim of the lamp holder to a plasterboard ceiling. I am trying to attach a (not very good) picture.
