What Do I Do With Rotting Deck Supports? - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-30-2012, 07:19 PM   #31
robertcdf's Avatar
Originally Posted by kwikfishron View Post
Zmax is what the local yard (Pro build) stocks along with SS. A 2x6 Zmax hanger is about a buck, in SS itís about $8.
The thing with the Oregon Coast anyway is that even with a Zmax hanger, if itís on a front row house you ďwillĒ have to replace the them within 5 years. At the 5 year mark they will likely come apart in pieces.
Just a few blocks off the Ocean it may take 7-10 years to see the same level of corrosion.
A couple of miles in it will take even longer yet but youíll likely still see some surface rust after the first year.
As we both know what works in one place can be a Train Wreck somewhere else.
Id be curios on what BuiltByMac's views are on steel deck joist in his area. Even though heís about 80mi inland from my costal location his area is still almost as wet (minus the salt).
So we should insult and throw out technology and options that work for 99% of the country based on 1%? There is a VERY good chance that this is a viable solution for the op.
robertcdf is offline   Reply With Quote
Old 06-30-2012, 07:45 PM   #32
Pro
JetSwet's Avatar
Rewards Points: 502
The solution would be to replace the joist or replace the deck. I don't think the op would replace the deck with the metal decking call me cynical but it's like putting a ferrari engine in a Honda you really only see those in highly $$$ homes.
If the op wanted to use a metal then should go with a TI Proboard then put tile on it right Infront of a ocean.
JetSwet is offline   Reply With Quote
Old 06-30-2012, 08:35 PM   #33
robertcdf's Avatar
I just put a steel frame deck on a $165,000 house, not exactly a high dollar home, I also put them on $500,000 homes. I find that I usually install steel frame decks for intelligent people who see advancing technology can be good. They see the VALUE of the frame is worth cost.
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
Deck post supports?? Mandy204 Building & Construction 2 06-09-2010 11:00 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
